Midi files: can I use music created using one of these commercially for an out of copyright song?
PostPosted: Thu Jan 10, 2019 9:28 am
by voiceoverchap
HI
I need to create some adverts using a very old traditional nursery rhyme (the song itself is out of copyright). So, can I use a MIDI file (rather than creating the arrangement myself) to create the track without any usage restriction? I would still be choosing the sounds etc from my own instruments, software etc.
Thanks.
Re: Midi files: can I use music created using one of these commercially for an out of copyright song?
PostPosted: Thu Jan 10, 2019 10:59 am
by blinddrew
Oof! Suspect you're going to need a proper copyright lawyer for that one. It will probably come down to the case law wherever you're based.
PostPosted: Thu Jan 10, 2019 5:10 pm
by The Red Bladder
Copyright questions are always questions of detail, so the answer is nearly always 'depends'.
If the MIDI file is not your own and can be identified by the style of the arrangement, then the answer is No!
PostPosted: Thu Jan 10, 2019 5:24 pm
by Wonks
Can you not get the sheet music and create your own MIDI tracks using that as a base?
PostPosted: Sat Jan 12, 2019 11:37 am
by voiceoverchap
It is a difficult one, I know. For example if a covers band doing gigs in clubs use Midi files as backing tracks, should they be paying a usage royalty to both the composer AND the MIdi file creator?
PostPosted: Mon Jan 14, 2019 9:46 am
by Still Vibrations
If the composition is in copyright then the no matter how original the arrangement, the copyright still belongs the composer. If the work is out of copyright then an arranged version may well contain copyright elements. Unfortunately some publishers will make a prosy piano version of a folksong and the put a copyright sign on the whole thing, implying the folksong itself belongs to them - which it does not.
If it is a nursery rhyme then I would do my own arrangement. If you don't want to for some reason, then you could always pay an arranger, or a keyboard player to produce a midi file. If you arrange music in notation software e.g. Finale, that can also be exported as a midi file.
