Poll for my university coursework
Poll ended at Thu May 02, 2019 7:47 pm
Yes
0
No votes
No
1
33%
I use an online service
0
No votes
I create my own Foley work/sound effects
2
67%
Total votes : 3
Postby BrendanTucker » Thu Apr 25, 2019 7:47 pm
Hi everyone I'm new here, I'm currently studying for my degree in music production. As part of the coursework, I'm required to post a questionnaire with relation to my business proposal of an independent Foley artist/sound effects studio. If you could answer my poll it would be immensely helpful.
Thank you!
Brendan
BrendanTucker
Re: Poll for my university coursework
Postby Logarhythm » Thu Apr 25, 2019 9:34 pm
Hi Brendan,
It doesn't seem to be especially clear what question you would like us to answer with your poll ;)
Logarhythm
Postby Agharta » Thu Apr 25, 2019 9:49 pm
Are you doing a degree in poll dancing then?
Agharta
Postby Still Vibrations » Fri Apr 26, 2019 7:22 am
Agharta wrote:Are you doing a degree in poll dancing then?
And psephology.
Still Vibrations
"It’s like the whole thing about punk is that you do brilliantly ambitious things very stupidly."  - Maria Damon (I think!)
Postby Dave B » Fri Apr 26, 2019 8:21 am
Brendan,
This is not what was intended when you were asked to do a questionnaire. We get a fair few of them on the forum and they are a proper series of questions designed to gather information about the people answering as well as asking questions about the main topic as well. I think that you need to go back and start from scratch - there are sites which will host these kind of surveys and let you post it as a link for people to follow and fill out.
If you have a search through the forums for 'survey' you can find some examples that you might want to have a look through.
HTH
Dave B
Postby Mike Stranks » Fri Apr 26, 2019 8:26 am
Welcome!
I do a fair bit of work with sound-effects - mainly, but not exclusively, location effects and sounds. I'm afraid your poll is poorly designed and needs a lot more work. For instance, to what precise question am I answering 'yes' or 'no'? And I can answer both 'yes' AND 'no'!
A bit of explanation of what I do may help you rethink your approach...
I provide sound-effects to an online library.
I use sound-effects from online libraries.
I sometimes get asked to provide a specific sound effect which subsequently finds its way into a library.
I create specific sounds for my own work which are not shared with anyone.
Hope that helps you reshape your questionnaire.
Good luck!
Postby BrendanTucker » Fri Apr 26, 2019 7:40 pm
Hi everyone,
Thanks for the feedback, I will create a new post with a link to my survey rather than using the poll feature.
BrendanTucker
Postby ReadySaltedChris » Sat Apr 27, 2019 4:22 pm
I have voted 'no' as I took it to mean 'do I need a poll for my university coursework'.
I hope I have understood correctly.
Cheers.
ReadySaltedChris
Postby Agharta » Sat Apr 27, 2019 5:07 pm
And psephology.
Phrenology would make a good partner unless you fall off your pole and bang your head which might confuse the diagnosis.
Agharta
