I get an occasional crash with 10.4.1 and the Wavey. Mainly on re-opening projects iirc. But it's by no means every time. It's infrequent enough to be a niggle rather than a problem.
I can double check OS versions, etc if you want.
Korg Wavestation instability in Logic Pro X?
• Page 2 of 2 • 1, 2
Dave B - Jedi Poster
Re: Korg Wavestation instability in Logic Pro X?
Unfortunately, it’s crashing Logic every time for me. I’m on High Sierra, LPX 10.4.1, Korfg Collection - latest versions of all of those. All other Korg Collection plugins work perfectly, but Wavestation crashes logic, every time it’s instantiated.
- Kevin Nolan
- Frequent Poster
Not used mine for a while so thought I'd give it a try. It seems ok but I'm I'm merely setting up a stereo instance and noodling - no recording etc but works fine. OS 10.13.6 and Logic 10.4.1......No crashes at all but not exactly deeply testing it!
fatbenelton - Frequent Poster
Jonny
I'm just using a stereo instance too - nothing deep on this end - just - every other of the 200 plugins I own work - but Wavestation - the moment I instantiate it - Logic - Puff!!!!
Completely unusable.
- Kevin Nolan
- Frequent Poster
fatbenelton wrote:Not used mine for a while so thought I'd give it a try. It seems ok but I'm I'm merely setting up a stereo instance and noodling - no recording etc but works fine. OS 10.13.6 and Logic 10.4.1......No crashes at all but not exactly deeply testing it!
Just checked mine too, doing much the same and so far no problem. (2017 iMac, 21.5" retina, if it might be relevant)
- Rich Hanson
- Frequent Poster (Level2)
Just got a reply from Korg UK with a solution. Probably should have tried this but it didn't occur to me:
1. Reinstall the KORG Collection software.
2. Delete the following AU plug-in cache: ~/Library/Caches/AudioUnitCache
3. Rescan the plugins using Logic's Plugin Manager.
As an aside - I find Korg UK support (which covers Ireland too) to be _absolutely_ fantastic. I've had a lot of dealings with them in the past couple of years and every time they have been incredibly friendly and hugely helpful. From buying spare parts to technical support - just brilliant every time. Just thought it worth flagging.
Kevin.
Kevin.
- Kevin Nolan
- Frequent Poster
Good to know as the owner of some Korg kit. Off-topic but quick call out for Softube support, who are both friendly and very effective. Needed them badly recently and they delivered the goods.
ConcertinaChap - Jedi Poster
Making music: Eagle Alley, recording music: Mr Punch's Studio.
A full wine rack is a happy wine rack.
