MBP 2009 odd behaviour.
Postby DAGGILARR » Tue Apr 17, 2018 10:15 am
I recently reformatted my old MBP, put El Cap on it and moved it on. Apparently now, and this is the description I have been given. "Every time I switch it on it keeps installing Capitan like it's not installed already on the hard drive."
I know this is not a lot to go on. I just wonder if anyone can make sense of what may be happening here?
DAGGILARR
iMac 27" i7 2.9gh 2010 12GB ram, Focusrite Pro24DSP.
Re: MBP 2009 odd behaviour.
Postby desmond » Tue Apr 17, 2018 10:54 am
Where is it installing El Capitan from?
What is your Startup Disk set to in System Preferences?
What drives are available when you hold Option while booting? Can you choose a different drive here?
desmond
Postby DAGGILARR » Tue Apr 17, 2018 11:13 am
I will check these things out. I do not have this machine in front of me. I know there is only one drive.
I will try and get a bit more info.
Thanks.
DAGGILARR
Postby DAGGILARR » Tue Apr 17, 2018 1:30 pm
The screen shows that it is installing to Mac hdd it also show a recovery drive.
DAGGILARR
Postby desmond » Tue Apr 17, 2018 2:04 pm
DAGGILARR wrote:The screen shows that it is installing to Mac hdd it also show a recovery drive.
You have downloaded the installer app from the App Store?
Generally speaking, during install, the machine *should* reboot, often more than once and continue the installation - are you letting this finish? It sounds like the installation isn't complete.
Or maybe try running it again...?
It's kind of difficult to remotely troubleshoot this kind of stuff...
desmond
Postby DAGGILARR » Tue Apr 17, 2018 3:26 pm
I assume the installer in the applications folder, maybe that should be removed?
DAGGILARR
Postby desmond » Tue Apr 17, 2018 3:34 pm
Well, it should remove i when the installation is complete.
So the installation hasn't been completed, for some reason.
Did you try again?
desmond
Users browsing this forum: BigRedX
