G4 Powerbook Battery
Postby Still Vibrations » Sat May 19, 2018 9:38 am
For music I use a 2003 GB Powerbook for basic recording/editing and then take everything to a studio with Radar and valve processors/eq to mix the final recording. I only use 3 - 8 audio tracks with no software instruments or internal effects.
Does anyone think it's worth replacing the battery and if so does anyone know where to get a replacement? Or is this laptop about to become unusable after all these years?
Still Vibrations
"It’s like the whole thing about punk is that you do brilliantly ambitious things very stupidly."  - Maria Damon (I think!)
Re: G4 Powerbook Battery
Postby Jumpeyspyder » Sun May 20, 2018 11:03 am
Hi SV,
I wouldn't reccomend spending much cash on a laptop of that age.
You don't know if something else is about to fail.
However, a battery (if you can find one ) is cheaper than a new laptop, so if the G4 still does what you need - you might get a some more use from it.
Which exact model is it?
I'm assuming its aluminium, 12" 15" 17"
There should be a model on the battery (you will need to take it out to see it)
Its probably something like A1057.
I did find a couple of sites that may have what you need - but I've not used either - so I don't know if they are legit!
http://www.good-batteries.co.uk/brand.php/APPLE+battery
https://www.thebookyard.com/contact.php
Jumpeyspyder
Postby Still Vibrations » Sun May 20, 2018 11:26 am
Good advice Jumpeyspyder. You guessed correctly, it's an aluminium 15" model and can only run 10.4.11.
Although I am really concerned about the environment, when my wife patched up her old computer other things went wrong soon afterwards.
I have just discovered that you can run a G4 laptop without a battery but of course the date and time have to be reset every time it's switched on.
Still Vibrations
