Microphone went dead after supper...
Page 1 of 4
PostPosted: Mon Sep 10, 2018 3:45 am
by audio_jungle
I have been playing around all day doing practice voiceovers.
Things have been going well, and I have recorded several project files in Audacity.
Before supper I unplugged my gear to clear off the table for supper, and when I hooked things back up to do a few more voiceovers before bedtime, my mic seems all but dead.
Now I am freaking out thinking I blew something up?! :cry:
I have a MacBook Pro, Sierra, Onyx Black, Cloud Lifter, Shure SM7B and Sony MDR-7506 headphones plugged into my Onyx.
TO MON is maxed out, and if I crank the GAIN to max and the PHONES to nearly max, I can bearly hear myself speaking into the Mic.
I have a virtual Lookback device setup with the "Audio Source" being my Onyx Blackjack.
One thing that seems strange, and I guess I never paid attention to what it was before is my Audio MIDI settings...
Here is the Onyx Blackjack...
Is that correct for those to be minimized and greyed out??
And here is my virtual Lookback device...
I sure hope I didn't blow up my microphone or audio interface or whatever?! :shock:
Re: Microphone went dead after supper...
PostPosted: Mon Sep 10, 2018 6:53 am
by Janneman
Goodmorning,
DO see any input coming into the mackie black?
If so. Unplug everything, restart your computer and plug in the interface again.
PostPosted: Mon Sep 10, 2018 7:43 am
by Sam Inglis
Yes, it's normal for those settings to be greyed out on 'professional' audio devices like the Blackjack.
Have you checked that phantom power is enabled? The SM7 won't need it but I think the Cloudlifter does.
PostPosted: Mon Sep 10, 2018 10:49 am
Don't panic! It's almost certainly a silly plugging error or incorrect setting. I think Sam could well be right about phantom power being switched off, but also check that you've plugged the Mic into the right channel -- it's easy to get them mixed up if you're leaning over from the front at.
Just work through calmly, checking everything in a logical progressive way. I'm sure you'll find the problem soon.
PostPosted: Mon Sep 10, 2018 12:25 pm
by Dave B
Hugh Robjohns wrote:Just work through calmly, checking everything in a logical progressive way
But on this one occasion, you can skip the sparkly cape and 20 minute mellotron solo .... ;)
PostPosted: Mon Sep 10, 2018 7:05 pm
by audio_jungle
Janneman wrote:Goodmorning,
I have green lights for: Power, USB, and Phantom
PostPosted: Mon Sep 10, 2018 7:16 pm
by audio_jungle
Hugh Robjohns wrote:Don't panic! It's almost certainly a silly plugging error or incorrect setting. I think Sam could well be right about phantom power being switched off, but also check that you've plugged the Mic into the right channel -- it's easy to get them mixed up if you're leaning over from the front at.
I think I have MAJOR problems...
Here is my current setup...
MacBook Pro => Onyx => CloudLifter => SM7B
Onyx Settings:
- Power on
- USB on
- Phontm on
- Gain (Channel 1): 1 o'clock
- Hi-Z filter off
- To Mon set at max (as usual)
- Phones set at 12 o'clock
Have my Sony MDR-7506's on, plugged into Onyx.
I hear steady static like a radio dial set to no station...
If I tap on the top of the mic with my finger I see the green light appear on Channel 1 signal indicator.
If I crank the Channel 1 Gain to 2 o'clock, the static is louder, and if I mouth the mic (like a rap star) and say "Test Test Test" I can barely hear my voice in the headphones, and there is a good chance that what I am hearing is my actual voice and not through the headphones...
I am starting to think I blew up my Shure SM7B, which is hard to fathom, considering that is a very rugged microphone!!
PostPosted: Mon Sep 10, 2018 7:51 pm
by Sam Inglis
It's possible the mic is faulty, but I think much more likely that you have a dodgy cable. Also, try plugging the mic in without using the Cloudlifter -- you'll need to turn the gain up to maximum but you should be able to get a clear signal.
PostPosted: Mon Sep 10, 2018 8:04 pm
by audio_jungle
Sam Inglis wrote:It's possible the mic is faulty, but I think much more likely that you have a dodgy cable. Also, try plugging the mic in without using the Cloudlifter -- you'll need to turn the gain up to maximum but you should be able to get a clear signal.
Working backwards...
Could I blow up an SM7B with too much power?
For example, if having both the Onyx'x Phantom power on PLUS the CloudLifter too much power?
What about if I plugged in another microphone? Could that happen as well?
These cables probably have less than 20 hours on them... Could they break that easy?
What about what I mentioned in my OP about the levels in the Audio MIDI Setup not looking right?
If things are minimized out, then maybe that forces me to crank up the Gain on the Onyx, and so it is like trying to suck water out of a straw?
PostPosted: Mon Sep 10, 2018 8:39 pm
by Watchmaker
Dave B wrote:But on this one occasion, you can skip the sparkly cape and 20 minute mellotron solo .... ;)
:clap:
Working backwards:
Everything was set up and working fine. You then folded up, had dinner and set it back up. it's fubar.
99.3% chance of operator error. Tear it down, have a beer. calmly set it back up.
by Sam Inglis
I think you're confusing power with gain here. The only source of power involved is the +48V phantom supply from the Onyx, which drives a small fixed-gain preamp inside the Cloudlifter. Changing the gain setting on the Onyx makes no difference to the phantom power.
The only way to find out what's broken is by swapping out different parts of the signal chain. The easiest places to start are by swapping out the cables and removing the Cloudlifter from the chain as previously suggested.
PostPosted: Tue Sep 11, 2018 11:57 am
by ConcertinaChap
audio_jungle wrote:[What about what I mentioned in my OP about the levels in the Audio MIDI Setup not looking right?
It may not look right but it really is OK. Here's mine, for comparison.
I'm afraid the others are right, you're just going to have to swap stuff around until it starts working again. Only change one thing at a time, though.
PostPosted: Sat Sep 15, 2018 4:53 pm
by audio_jungle
Week from HELL from work last week... :roll:
Finally getting back to my aduio gear this morning.
I found two un-unsed XLR cables, so will take the advice above, and *pray* that it is something dumb, and not a technical issue, as I really want to get my IVR done!
Stay tuned...
PostPosted: Sat Sep 15, 2018 5:14 pm
by audio_jungle
Sam Inglis wrote:I think you're confusing power with gain here.
Not sure that I follow you...
My understanding is that certain microphones - usually condenser mics - require more power than a conventional dynamic mic, right?
So "phantom power" is that extra voltage, right?
What is confusing me, is that I thought the CloudLifter somehow provided extra power too? (I'm not an electrical engineer, so not sure how all of that works, but I thought the CloudLifter somehow stored up the power coming out of your audio interface and gave you extra power as well?)
Can you extra some more what what is the difference between extra power and what a "preamp" and "amplification" in general does/means?
Sam Inglis wrote:The only way to find out what's broken is by swapping out different parts of the signal chain. The easiest places to start are by swapping out the cables and removing the Cloudlifter from the chain as previously suggested.
If I plug a non-condenser microphone into my Onyx, and turn on the Phontom power, will that ruin something like my Shure SM7B mic or my field reporter Electro-Voice RE50N/D-L mic?
PostPosted: Sat Sep 15, 2018 8:33 pm
by Sam Inglis
A microphone converts acoustic energy into electrical energy, outputting a very low-amplitude signal. This needs to be pre-amplified before it reaches the analogue-to-digital converter and is transformed into a stream of numbers that your computer can record. This pre-amplification is done using active circuitry which requires power to operate. That power can come from a mains supply, from USB bus power or even from batteries.
Some mics require more pre-amplification than others, which is why preamps have a Gain control. A few mics require so much pre-amplification that the preamp in an interface such as the Onyx might struggle to deliver enough gain. But this has nothing to do with electrical power, it's just that those mics (the SM7B is one) lie outside the range the designers of the audio interface were anticipating.
Some microphones also have active circuitry in them which requires power to operate. This includes all capacitor (condenser) mics. Nearly all of these mics are designed to draw that power from your mixer/audio interface through a 48V phantom power supply. The amount of power the mic draws is minimal -- usually much less than 1 Watt -- and is always the same.
Other mics, including the SM7B, are completely passive devices, meaning they draw no electrical power at all.
Moving the Gain control on your preamp doesn't significantly vary the amount of electrical power drawn either by the mic or the preamp, and in any case, the amount of power needed is relatively small.
Essentially, you could think of the Cloudlifter as a device that turns a passive mic (such as the SM7B) into an active mic, delivering a stronger signal so that the interface preamp does not need to apply so much gain. It too is an active device that takes its power from the phantom supply. It applies a fixed amount of gain and its power draw should be the same regardless of how loud or quiet the signal is.
Phantom power is designed to be 'invisible' to passive circuits, so there is no possibility of damaging your SM7B by accidentally applying phantom power to it. But the SM7B doesn't benefit from phantom power or need it in any way.
