Logic Pro: Samply The Best
Postby forumuser930499 » Fri Dec 07, 2018 7:13 am
I had read this article: https://www.soundonsound.com/techniques ... amply-best
Sounds great, but it's not in every situation like that. For excample. I sampled a lot of synths in the past. After I finished the article, I open my logic x and try to get those sampled EXS24 MKII Presets in the Logic Alchemy, I follow all the steps, but my personal stuff is hidden. I could load the factory stuff of the EXS24 MK II in Alchemy, but that is not what I want. In the net I found that others have the same result.
I have also an Original Camel Audio Alchemy 1.5. If I translate this EXS24 PResets with Chicken System Translater 6 into an sfx file, I can load it in that, if I directly switch to the logic alchemy it's also there. But in the logic Alchemy it's not possible to load sfx files, as I see.
Also there is another probblem the loopsetting don't walk into Alchemy.
Another thing is Alchemy has not unisono Botton.
Some one another idea? Thanks in advanced
forumuser930499
Re: Logic Pro: Samply The Best
Postby desmond » Sat Dec 08, 2018 10:25 pm
forumuser930499 wrote:I follow all the steps, but my personal stuff is hidden.
I don't know what you mean. Do you mean how to get your use user Library folder (/Users/*you*/Library/ ..etc)
You can also move your user EXS files to the new location of ~Music/Audio Music Apps...
desmond
Postby forumuser930499 » Tue Dec 25, 2018 4:10 pm
As I understand right now, you can use the Autosampler Instruments only. Also the Alchemy has not all the possibilities like the EXS24 MKII. It could be a good possibility but Sampling runs better in EXS24 MKII
forumuser930499
