Just downloaded a couple of new AU instruments from AIR but although I seem to have authorised them, they don't appear in Logic's plug in manager. The actual AU Components are in the components folder with all my other plugs though. The plugin help site says you should delete the components cache then rescan. But this means I have to rescan ALL my existing plugins and then go through the whole palaver of switching them on and off etc in the Plug in Manager.
So is it possible for Logic to just scan a single new plugin somehow?
Logic Pro X. Can you just scan a single new AU plugin?
• Page 1 of 1
Dr Huge Longjohns - Frequent Poster (Level2)
Re: Logic Pro X. Can you just scan a single new AU plugin?
Before doing anything, restart your machine, and see if they show up now.
The behaviour of later OSX versions (HS onwards) means you often need a restart before a new plugin will show up.
Try that, and if they still don't show, post back and I'll help...
desmond - Jedi Poster
Cheers, D, I'll give it a go.
Also, when you start Logic after installing a new plugin, you'll see that it will validate the plugin on launch, so you get a kind of visual comfirmation that Logic's found a new plugin.
If you install a plugin, start Logic, and don't see it doing a plugin validation procedure the first time, reboot and try again. If it's still not showing up, check out another app that uses AU plugins (say, the excellent and free HostingAU) and see if it shows up there.
If nothing else, you can trash the AU cache and re-validate all your plugins, but this is a bit of a last resort as it can be quite a lengthy hassle, depending on the plugins on your system...
Yep, restarting worked, although one of the plugins only gives me a sort of thunk noise for each note even though the GUI seems fine. Hey ho.
Yes, it was the long-winded full rescan I wanted to avoid, it's a total and utter pain if you've got a lot of plugs, as I have, to trash the cache etc. Cheers
So the problem with the AIR plugin seems to be that Logic can't find the actual samples. I opened Garageband to see if it worked there, and GB asked me to locate the samples folder manually. WHich I did, and it worked. But LPX hasn't prompted me to locate the samples or anything similar. Is there any way to ask it to do this? The instrument interface has no option for this.
EDIT: Just did some searching and seems to be a very common issue with this plugin, and one that the makers are not really addressing. Ah well, it WAS free so can happily live without it.
Dr Huge Longjohns wrote:So the problem with the AIR plugin seems to be that Logic can't find the actual samples. I opened Garageband to see if it worked there, and GB asked me to locate the samples folder manually. WHich I did, and it worked. But LPX hasn't prompted me to locate the samples or anything similar. Is there any way to ask it to do this? The instrument interface has no option for this.
How the plugin works has nothing at all to do with Logic.
What plugin is it? What does it's installation manual say about the position of it's content?
I would have thought that if you have to choose a sample path for it's own content, it will remember that, so if you've done that (regardless of the host you did it in) it would work the same for all hosts.
Yes, you'd have thought so but see my edit above. Seems to be an issue in both Logic and Pro Tools for lots of people so I'm sort of mentally writing it off as it was just part of a free bundle.
What plugin is it?
I have Xpand2, Hybrid2 and Vacuum in Logic working without problems...
Mini Grand. Now sorted. I called UK support who didn't have any ideas and suggested I email the US support team who, impressively, replied immediately and pointed me to an update to download. Downloaded it and it's now working. Amazing the UK team didn't know about this issue/solution as it's clearly not a rare one despite what they said. Anyway, all's well etc, thanks D.
Not only that, as the presets disappeared with the update (which I rescued by opening the original DMG and fishing them out) and the US support chap was clearly a bit peeved with the UK not doing their job for me etc, he gave me a free choice of plugin up to $100!! How about that for customer service above and beyond? Seriously impressed. Got the the Boom drum machine.
Actually for recent OSXs not picking up the AU after install you just need to log out and back in, a full reboot is not required.
Interestingly this is only required for 64 bit plugins, 32 bit ones don't suffer from this new "feature".
BobTheDog - Frequent Poster
I’ll try that next time, cheers
