Why is my Mac Pro booting slow ?
Postby Gone To Lunch » Sat Feb 02, 2019 11:34 am
My Mac Pro, High Sierra 10.13.6 is booting slower and slower, first attempt this morning, after about 15min, of extremely slow status bar below the apple logo, I re-started via the power button and it was quite a bit quicker, but much slower than it has been ordinarily.
What might this be, and how might I fix it ?
Gone To Lunch
http://www.gonetolunchmusic.com/
Re: Why is my Mac Pro booting slow ?
Postby desmond » Sat Feb 02, 2019 2:15 pm
Drive problems? Hardware problems?
Do a disk check using disk utility...
desmond
Postby Gone To Lunch » Sat Feb 02, 2019 4:59 pm
Well, I closed down and then re-started, and the problem went away.
So that's that.
For now.
Gone To Lunch
Postby Gone To Lunch » Thu Jun 06, 2019 5:33 pm
Problem is back again.
Ever slower status bar under the apple log when I boot.
Gone To Lunch
Postby desmond » Thu Jun 06, 2019 6:00 pm
Gone To Lunch wrote:Problem is back again.
Every time, or just once? What happened when you tried the suggestions I already made above?
desmond
Postby fruitcake » Thu Jun 06, 2019 9:49 pm
Check your console logs. Also try starting up in verbose mode. It can help tell where the boot up is hanging.
fruitcake
Here are some Unfinished Sounds
Postby Gone To Lunch » Sun Jun 16, 2019 11:07 pm
My mac is bootable from two drives, System with 10.11.3, and Projects with 10.13.6 so I re-selected the boot drive from my preferences and that seemed to cure it for a while.
I have since booted from Projects so as to run the disk repair utility on System and that helped for a couple of boots, but it is now back again when I boot from the preferred System drive.
I have tried safe booting, and that stops it.
Gone To Lunch
Postby MOF » Mon Jun 17, 2019 12:40 am
Did you try First Aid in Disk Utility also is there at least 10% spare capacity on your boot drive?
MOF
Postby Kwackman » Mon Jun 17, 2019 9:06 am
Gone To Lunch wrote:I have tried safe booting, and that stops it.
Consistently?
Kwackman
Postby Gone To Lunch » Mon Jun 17, 2019 9:15 pm
MOF wrote:Did you try First Aid in Disk Utility also is there at least 10% spare capacity on your boot drive?
Yes, and there is 50% spare capacity on that drive
Gone To Lunch
Postby Gone To Lunch » Mon Jun 17, 2019 9:16 pm
Consistently?
Don't know, I only did it once, and running the repair utility seems to have done the trick.
And I also re-selected the drive from within the system preferences and that seems to clear it as well.
Gone To Lunch
Postby Gone To Lunch » Tue Jun 25, 2019 2:14 pm
It happened again so this time I emptied the cache - for the first time - I have this mac for 3 years - and that got it back to normal.
Gone To Lunch
Postby MOF » Tue Jun 25, 2019 2:31 pm
Which cache?
MOF
Postby Gone To Lunch » Tue Jun 25, 2019 11:27 pm
Which cache?
Open Finder, select “Go”, click “Go to folder”, type “Library/Caches/”, delete all files, and empty trash.
Gone To Lunch
Postby MOF » Wed Jun 26, 2019 1:51 am
OK thanks, that sounds pretty comprehensive, I hope you didn’t throw some babies out with the bath water.
MOF
Next
