Best way to add a second monitor 20ft from the main computer
Postby AndyN » Fri Feb 22, 2019 2:11 pm
Hi All,
I am thinking about adding a second monitor (visual) to my system but by the time the cables go around the room they will need to be about 15-20 ft long. My computer is a late 2013 iMac with a mini-display port output. I have read that the quality of signal reduces after about 10 ft. What would be my best option? I only want to mirror the primary display.
Andy
Just realised that this should have gone in the Mac forum - sorry. Not sure how to change it.
AndyN
Re: Best way to add a second monitor 20ft from the main computer
Postby zenguitar » Fri Feb 22, 2019 2:40 pm
I've moved it for you :thumbup:
Yogi Berra
Postby Ramirez » Fri Feb 22, 2019 2:43 pm
zenguitar wrote:I've moved it for you :thumbup:
The whole 20ft?
Ramirez
Postby Wonks » Fri Feb 22, 2019 3:46 pm
Just halfway. Now you only need two 10' cables so everything's fine!
Postby AndyN » Fri Feb 22, 2019 11:23 pm
Thanks Andy, you mods always go the extra mile - which is more than can be said for my cable!
AndyN
Postby ef37a » Fri Feb 22, 2019 11:45 pm
From what I read, HDMI cables up to 5mtr are of basic construction and work well.
For a 10mtr cable the wire diameter should be increased to reduce losses, so more expensive even than twice a 5mtr jobby. It seems up to 15mtr or so can be used without issues?
Does the remote monitor have a MD port? If not you will need an adaptor to get to HDMI. I bought one for my son's Lenovo laptop, worked fine.
Postby AndyN » Sat Feb 23, 2019 6:25 pm
Thanks Dave, I shall look into that. I haven't decided on a monitor yet but am looking into the feasibility of it.
Andy
AndyN
Postby ef37a » Sat Feb 23, 2019 6:37 pm
AndyN wrote:Thanks Dave, I shall look into that. I haven't decided on a monitor yet but am looking into the feasibility of it.
Andy
Right, I have found there IS such a thing as a monitor with a Mini Display port input but the cables are expensive compared to HDMI (which is everywhere and you can buy in line couplers from B&Q!) so I would adapt up to HDMI and buy from Rock Bottom!
Postby MarkOne » Tue Feb 26, 2019 4:32 pm
when we had a ceiling mounted HD projector set up in our old house I happily ran a 10m HDMI through the ceiling and down to the AV distribution amp with no problems.
I don't even think it was a particularly expensive HDMI, we just got whatever Screwfix had on the weekend we did the installation.
Some things are just fussier than others... For instance our Sky box didn't like a cheapo 1m HDMI going to the same AV amp and would only work with a stupidly overpriced one where the very same cheapo cable was fine with the BluRay player... Go figure
MarkOne
Location: Bristol, England, Earth, Perseus Gap, Milky Way
