Caught a sniffle
Caught a sniffle
Postby MadManDan » Thu Jun 27, 2019 5:06 pm
Hi. . I've been set up on my mid 2014 mini, high Sierra, event free for one year. Last night I tried going to a reputable website and something went wrong. I was asked to install flash which seemed weird but being tired I clicked.
Now it seems like I've caught something as both chrome and safari have some unexplained search engine as their homepage and I keep getting suspicious pop ups.
So fortunately I have kept a copy of the entire boot drive on an external, via carbon copy cloner.
Should I re make the system from that, or is that too extreme a measure?
MadManDan
Gear list: If you can't find it, grind it
Re: Caught a sniffle
Postby desmond » Thu Jun 27, 2019 5:22 pm
Given that you don't know what the malicious software is going to do, then yes, I'd restore the system...
Peace of mind, and all...
You could always do some research on the particular thing you have (you should be able to google some suspicious-looking process names etc), but you don't want to risk having your data permanently encrypted or something...
Postby ConcertinaChap » Thu Jun 27, 2019 10:17 pm
Desmond has the right of this. Your system has been (as the modern jargon has it) pwned.
ConcertinaChap
Postby MadManDan » Thu Jun 27, 2019 11:10 pm
Thanks. Now I need to look into method for this. I know it begins with booting in safe mode?
MadManDan
Postby ConcertinaChap » Thu Jun 27, 2019 11:34 pm
I think you need to determine how the backup you made with carbon copy cloner should be used for this purpose.
ConcertinaChap
Postby Jumpeyspyder » Fri Jun 28, 2019 12:37 am
Hi
First thing to do is check your 'compromised' system for any data that you need to backup and stash it away (ideally on a separate disk - not on your 'clean' CCC backup)
Next, check if your CCC backup is bootable and works!
Boot your mac hold down 'Alt' and it will hopefully present your external drive as one of the boot options - select it and check that it boots up fine!
If you do both these two things it gives you options!
Jumpeyspyder
Postby MadManDan » Fri Jun 28, 2019 1:55 am
Luckily there's nothing to back up. I can go straight to booting up from external. I assume the mac will presume that since I'm doing this I am planning on some utility work
MadManDan
Postby MadManDan » Fri Jun 28, 2019 2:20 am
I'm at it now. Basically I booted from ext.
I then opened up the main hd and see the four corresponding folders : applications library system and users.
Starting by putting the applications in the trash and dragging the ext drive applications folder over. Plan to repeat for all four
MadManDan
Postby MadManDan » Fri Jun 28, 2019 3:36 am
OK That went horribly. Luckily it occured to me to use CCC. Hello, that's what I should done first :headbang:
LOVE Carbon Copy Cloner. First of all, it saw me booting up from ext and offered me a new "event" to restore the hd. Correct assumption, thanks.
And, it gave me the option to exclude certain files. Which I appreciated because the drive's not only my system back up, it also holds my SD3 library.
ANNND offered me tutorial videos. Hats off to CCC
MadManDan
Postby ConcertinaChap » Fri Jun 28, 2019 7:03 am
Lovely! Good result.
ConcertinaChap
Postby xFasterMikeyH » Fri Jun 28, 2019 6:00 pm
Sounds like you're all sorted, but from your description it sounds like this:
https://www.theregister.co.uk/2019/06/0 ... on_hijack/
xFasterMikeyH
Postby desmond » Fri Jun 28, 2019 6:34 pm
MadManDan wrote:I then opened up the main hd and see the four corresponding folders : applications library system and users.
I started to read that with dawning horror... :shock:
MadManDan wrote:OK That went horribly.
Well, yes... There are more things to a disk clone than just the visible files you can see in a Finder window!
(Hidden files, the whole Unix system, the boot stuff etc etc).
MadManDan wrote:Hats off to CCC
This is an all-too-common situation though - people happily making backups of their drives, without the slightest knowledge of what to do to restore from them, should the need arise...
Glad you figured it out without too much trouble..! :thumbup:
Postby MadManDan » Fri Jun 28, 2019 9:17 pm
So yeah, I got hijacked. :protest:
Here's the thing, the CCC restore went fabulously. BUT, my chrome still wants to make some nasty hijack search engine its home. And going into the expert settings, where you can manage which searches are used for the homepage, it does NOT allow me to remove it. Instead of the "remove" option it has a blank space. So bad. chrome://settings/searchEngines
I want this clean before I install anything else, as I'd like my next CCC clone to be of a clean HD
MadManDan
Postby MadManDan » Fri Jun 28, 2019 9:21 pm
dawning horror :D
MadManDan
Postby Jumpeyspyder » Fri Jun 28, 2019 10:22 pm
If CCC backup on external is good, and no futher backups required:-
normal practice is to wipe internal drive and use external to clone back to internal drive.
Glad it has worked ou for you :)
Jumpeyspyder
Postby xFasterMikeyH » Fri Jun 28, 2019 10:44 pm
MadManDan wrote:Here's the thing, the CCC restore went fabulously. BUT, my chrome still wants to make some nasty hijack search engine its home.
Are you sure that the restore went well? And that the point in time you restored from was prior to this happening? Because _everything_ should be back as it was before. Unless Chrome has some setting that allows you to share your preferences across devices, which it has then pulled down from the internet when you've started up your restored system.
xFasterMikeyH
Postby MadManDan » Sat Jun 29, 2019 12:15 am
I'm very careful and deliberate with this mac. I'm certain that my backup was before catching the bug. Plus I know when I caught it ....
The other night I needed support for my superior drummer 3. Apparently I went to toontracks.... With an s.... And they pushed a flash player on me.  Was tired so downloaded it. Don't judge :)
MadManDan
Postby MadManDan » Sat Jun 29, 2019 1:17 am
Should I think about wiping the HD and do the restoration again? Seems like over kill
MadManDan
Postby blinddrew » Sat Jun 29, 2019 10:31 am
I assume you have tried uninstalling then reinstalling Chrome?
Postby xFasterMikeyH » Sat Jun 29, 2019 5:56 pm
MadManDan wrote:Should I think about wiping the HD and do the restoration again? Seems like over kill
Just to be clear (and no judgment from me), are you saying that after doing the restore of your system you then installed a possibly dodgy flash player? And that since then you are seeing unexpected/weird behaviour from Chrome?
If the answer to those is 'yes' I would say that yes you should restore again. If you've accidentally installed a variant of the malware I linked to, it could be doing all kinds of nasty things - basically it has the potential to read all your internet traffic and doing what it likes with it. Including stealing passwords.
FMH
xFasterMikeyH
