Pulsing whoosh noise from monitors
Postby DAGGILARR » Sat Jul 06, 2019 12:39 pm
What could account for such interference from a Focusrite Saffire Pro 24 DSP? Not coming through headphones.
DAGGILARR
iMac 27" i7 2.9gh 2010 12GB ram, Focusrite Pro24DSP.
Re: Pulsing whoosh noise from monitors
Postby torinkrell » Sat Jul 06, 2019 5:29 pm
If you haven't already, separate your audio level wiring from the power cords. Then plug all the power cords into the same wall outlet with a power strip as needed (star connection). This will reduce/eliminate ground loops, EMI and RFI issues, and may completely resolve your noise problem. I have used this simple tip for over 20 years in multiple home studio installations near a major interference laden city and it has always resolved and prevented noise issues. In any event this star connection for your power is best practice in a usual home studio (that isn't built within a Faraday cage) and can at least rule out external interference and help you focus on equipment malfunction if it doesn't resolve your noise issue.
torinkrell
Postby James Perrett » Sat Jul 06, 2019 5:39 pm
Most likely to be a grounding issue - either a ground loop or a lack of a good ground in the system. If this has only just started then check that all your cables are properly connected.
