UAD Apollo min spec seems high given it's DSP anyway (quad core i7)?
Page 4 of 5
Re: UAD Apollo min spec seems high given it's DSP anyway (quad core i7)?
PostPosted: Sat Jul 20, 2019 11:19 am
by ConcertinaChap
jellyjim wrote:Plenty to learn but looking ahead; If I want more DSP I can get a Satellite, correct? If I want more inputs I can get something like a Focusrite Scarlett OctoPre connected by ADAT?
I've done both of those things with my UAD kit with no issues at all. In the end I sold my preamp and Satellite and bought a Silverface secondhand to increase both my DSP and preamp count. I did this because I quickly came to prefer setting preamp gains in Console and being able to save them between sessions to fiddling around on the preamp itself. One of the really nice things with UAD kit is if you add a second Apollo (or more) then it automatically gets aggregated with the original unit and appears alongside the original unit in Console and is available in Logic with no further action. Simple and sweet.
jellyjim wrote:A couple of those and I don't really need a mixer anymore do I?
'Fraid so.
jellyjim wrote:Looks like I've gone Back in The Box! :headbang:
Come on in, the water's lovely!
PostPosted: Sun Jul 21, 2019 10:55 am
by jellyjim
ConcertinaChap wrote:In the end I sold my preamp and Satellite and bought a Silverface secondhand to increase both my DSP and preamp count. I did this because I quickly came to prefer setting preamp gains in Console and being able to save them between sessions to fiddling around on the preamp itself.
Do only UA audio sources appear in console or can other audio inputs?
I'd use the Octopre 'statically', as in there'd be external gear more or less permanently plumbed in
PostPosted: Sun Jul 21, 2019 11:56 am
by Watchmaker
I have 3 UAD quad core, one in my Apollo 8 and 2 satellites and a late 2013 iMac with 3.GHz i5,16G. I LOVE my system. Works great. I plumb both a focusrite 8PreX and an audient ASP880 through the apollo, though I can only get 4 channels from each because UAD's through put on toslink is limited. This is totally configurable in the UAD console and renaming flows through to Studio One i/o
The fact that UAD bundles their plug-ins as a single library is a pain point, but you can hide them if you want though it's a clunky interface and the weak point imo. I don't see why they can't auto hide. You will have to hide them in both the control panel and your DAW. But it's a one and done so if you like the quality, it's worth it.
Compared to Waves, it's much, much better - for the way my mind works. And everything in the land of computers eventually gets put aside by the manufacturer for exactly the same reason so that whole train of thought, to me anyway, is a complete red herring. Scales and all. You will at some point have to commit to one system, all that's required is deciding which one and then learning to accept its limitations.
PostPosted: Sun Jul 21, 2019 12:15 pm
by ConcertinaChap
jellyjim wrote:Do only UA audio sources appear in console or can other audio inputs?
All the inputs on the Apollo appear in Console, so all the ADAT inputs each have their own channel. As you'd be attaching the Octopre by ADAT that's where it's outputs would show up. Of course you would have to set the output level of the Octopre preamps on the Octopre itself, which was why I eventually sold my Mackie Onyx 800r because I found digitally controlled preamps addictive.
Personally I like Console quite a lot. I'm told the RME equivalent is more versatile but with a higher learning curve. That may be so but Console hasn't stopped me doing anything yet and some things like comfort reverb are wondrously easy.
PostPosted: Sun Jul 21, 2019 12:29 pm
by jellyjim
Ah yes, good point. They're effectively Apollo inputs as they come via its ADAT input
ConcertinaChap wrote:Personally I like Console quite a lot.
Yes, I'm enjoying it so far, even on a cramped 11" screen! :headbang:
Gizmo for big screen is in the post
PostPosted: Sun Jul 21, 2019 12:37 pm
by MOF
You can also save different setups in Console, so for example a unison enabled guitar amp’ with reverb and delays that are recorded with or without effects then another for vocals with a unison enabled compressor and effects there to give you a nice wet sound but only the dry compressed sound is recorded.
PostPosted: Sun Jul 21, 2019 9:57 pm
by ConcertinaChap
MOF wrote:You can also save different setups in Console
This is part of the charm of the thing. For instance I sing with a three part close harmony group and I know which mics to use for which voices. I have a console template saved for the group and a Logic template also. To record I have to rig the mics, of course, but then I can just call up the templates and be recording in seconds. I love templates and have loads for both Logic and Console.
PostPosted: Tue Jul 23, 2019 1:18 pm
by jellyjim
Can you expand its outputs? I’m thinking not as it has ADAT in only, although I have read ADAT is bi-directional. I ask because i saw something that suggested otherwise as I was stumbling around the internet, though it was vague.
Edited: I meant outputs not inputs!
PostPosted: Tue Jul 23, 2019 1:38 pm
by ConcertinaChap
Everything is in the image:
Optical (i.e. ADAT or S/PDIF as you choose) is input only. You'd have a second port if it was output as well. So you're limited to the four line outs plus the headphone socket on the front.
PostPosted: Tue Jul 23, 2019 1:43 pm
by jellyjim
Thought so, thanks
And, all good! Not needing them, just wanted to clarify
PostPosted: Tue Jul 23, 2019 2:21 pm
jellyjim wrote:...although I have read ADAT is bi-directional.
Erm... the physical implementation is often bi-directional, using pairs of fibre connections, but each individual fibre connection carries up to eight channels one way only!
PostPosted: Tue Jul 23, 2019 2:23 pm
by jellyjim
Thanks. I obviously stumbled into some very ill-informed corner of the Internet. Thank the Internet Gods for SOS! :)
PostPosted: Tue Jul 23, 2019 2:31 pm
:D :thumbup:
PostPosted: Tue Jul 23, 2019 4:02 pm
by John Christopher
jellyjim wrote:Thanks all
Further research reveals to me that you're forced to download their entire library regardless of what you own! Urgh. Aggressive sales techniques or what?
But also terrible user experience if I can't hide the plug-ins I don't own. When or wherever I might select a UAD plug-in, will I always see those I don't own?
That'd be a deal breaker because for me it would be passion killer, so to speak, or at the very least an irritation ready to interrupt one's flow.
Although UAD requires downloading/installing the entire plugin library in one go, after the installation you can save disk space by deleting all individual unused/not-owned plugins simply by dragging them from your system to the trash. It's tedious but effective.
Also, if you choose not to delete unused plugins (to keep them available for Trial periods), UAD Console provides an option to Hide any individual plugins you choose not to view.
PostPosted: Tue Jul 23, 2019 4:16 pm
by desmond
John Christopher wrote:Although UAD requires downloading/installing the entire plugin library in one go, after the installation you can save disk space by deleting all individual unused/not-owned plugins simply by dragging them from your system to the trash. It's tedious but effective.
Yes, but they all come back when you update to UAD software. :headbang:
Much better imo to "hide" them in your DAW if you can, as you only need to do it once, it's non-destructive, and updates won't affect anything...
