Logic: freezing doesn't freeze! CPU save trick!
Postby Dr Huge Longjohns » Thu Sep 12, 2019 5:09 pm
I've been having lots of problems with high CPU in projects that at face value shouldn't be overly taxing for Logic on my well-specced Macbook (16gigs of ram etc). I've had projects recently where every track is frozen but still getting huge cpu spiking, to the extent that opening a new plugin window or switching to the mixer view would crash Logic instantly.
So I've been doing a load of experiments and discovered something new to me. This may be a 'of course it does that, you silly fool, Longjohns!' moment for all of you but just in case, I thought I'd post here.
So what I realised/discovered is this: if you freeze a track eg an EXS24 synth with a heavyweight plugin on, the synth and plugs carry on using loads of CPU even though you've rendered the audio. I couldn't understand why my projects were still using huge power even though literally every track was frozen. (And this is with the full green freeze before you jump in with 'you must be using the blue pre-plugs freeze, old boy!')
So what you have to do is you freeze the track then switch off the plugins and instrument and, bingo, super-low CPU usage. Alternatively you can bounce in place, of course, and then switch off the plugs and instruments on the original track or delete them completely.
As I say, if this is old news to everyone, Sorry! Game changer for me, though. (Although Abbey Road Chambers is still virtually unusable if you have it on a send. :roll: )
Dr Huge Longjohns
Re: Logic: freezing doesn't freeze! CPU save trick!
Postby un_quantized » Mon Sep 16, 2019 9:33 am
Thanks, this is handy to know as I have had similar problems.
It doesn't completely help as I like to have the plug-ins active for further tweaks on the frozen audio.
Another trick I found that helped with CPU spikes is to move plug-ins from the actual track to a new bus, then route the track output to the bus. In the CPU meter you can see that the load is often on one or two cores, this trick seems to re-distribute the load.
un_quantized
Postby Dr Huge Longjohns » Mon Sep 16, 2019 10:00 am
So you're using the track output rather than a send? That's interesting too, thanks!
Dr Huge Longjohns
Postby un_quantized » Mon Sep 16, 2019 12:52 pm
Dr Huge Longjohns wrote:So you're using the track output rather than a send? That's interesting too, thanks!
No, not to replace sends.
When a track gets loaded with some thirsty in-line plug-ins in the Audio FX area, copy all of these to a new bus and send the output of the track to the bus. For some reason this shifts the load around the CPU cores.
un_quantized
