8x8 midi interface shows up as 9x9?
Postby Waltern8tor » Wed Nov 27, 2019 7:47 pm
Hi All
Just bought a EDIROL UM-880 8x8 interface
But In CoreMIDI it shows up as 9x9 interface?
Any ideas as to why the 1 extra input and output...?
It has 2x USB ports but these are both switchable input only for connection to a computer.
Bit stumped as You can only connect to 8 physical ports...
It's installed under its generic USB midi driver
(Is the Roland USB driver still supported?)
Running on High Sierra
Cheers
Waltern8tor
"In space no-one can hear you scream".
Re: 8x8 midi interface shows up as 9x9?
Postby G-Doubleyou » Thu Nov 28, 2019 7:12 pm
Could be SPDIF stereo I/O, take a closer look at your specs.
G-Doubleyou
G-Dub Studio G-fx 2011 15inch 2.0GHz quad-core i7 Macbook Pro, LPX 10.3.2
2.3 GHz quad-core i7 Mini
Postby Waltern8tor » Thu Nov 28, 2019 7:57 pm
No Audio or spdif. It's a midi / USB interface :crazy:
Waltern8tor
Postby Rich Hanson » Thu Nov 28, 2019 9:13 pm
Could it be an internal loopback?
Rich Hanson
Postby Rich Hanson » Thu Nov 28, 2019 9:22 pm
Just perused the user manual, looks like the extra MIDI I/O is the control port for the UM880 itself - see page 38 and page 48.
Rich Hanson
Postby Kwackman » Thu Nov 28, 2019 9:25 pm
Yup, from the review in SOS
"There's also a useful Setup mode that lets you select which MIDI inputs will transmit data to the USB port, specify a control port (which shows up in your computer as port nine) to transmit the current patch or a bulk dump of all patches to a sequencer, initialise one or all of them, switch between various startup modes, or return the entire unit to its factory preset condition."
Full review here...
https://www.soundonsound.com/reviews/edirol-um880
August 2002!!
Kwackman
Postby N i g e l » Thu Nov 28, 2019 9:39 pm
Its more than just an 8x8 interface - its also a patchbay/router with a merge module.
The extra channel might be for the box itself so that the computer can configure it and load / save presets.
Postby Waltern8tor » Fri Nov 29, 2019 5:51 am
Ahhhhhhh.... that explains it :headbang:
Thanks guys! :thumbup:
Waltern8tor
