Rewiring cubase to protools.
Re: Rewiring cubase to protools.
Postby The Elf » Wed Dec 11, 2019 12:02 pm
My story is similar, but begins with Pro-16 on the Commodore 64! :ugeek: (I never find myself needing the Drum Editor, though!) :lol:
Kwackman is soooo right. You need to choose a DAW for how YOU want to do things. All DAWs can produce perfectly good results; the rest is just to how you like, or need, to work. There are a few great choices out there.
BTW Cubase's 'support' is worth every penny of 'free'. If support is important to you I would look elsewhere, TBH.
Postby MadManDan » Wed Dec 11, 2019 2:57 pm
Yes, it was the need for slick drum prog that really got me evaluating my midi situation.
I am attracted to what I've read about cubase's sophisticated quantize options and its easy to map drum grid. Especially now that I've found a superior3 template to pop into the key names.
What I haven't found yet, searching an enormous user manual pdf on my phone, is how to fully emulate a drum machine.
I'd like patterns and song so I can play with arrangements. As it loops around I'd like a delete key to wipe out mistakes.
Does groove agent get used for this? Firing off superior?
MadManDan
Late '14 mini 3 GHz i7 16 GB
Hi Sier 10.13.3. Glyph atomic. FF Scarlet 18i8.
Sup Drum 3. Pro Tools 2019.6.0.  iCon iKb 8x.
Mics, spkrs, 'phones, gtrs, greedy cat
Postby MadManDan » Wed Dec 11, 2019 3:03 pm
The Elf wrote:BTW Cubase's 'support' is worth every penny of 'free'. If support is important to you I would look elsewhere, TBH.
Honestly with PT I needed maybe an hour or two per year , if that, on the phone with a tech when I really couldn't sort it out with help from y'all
Not sure if this posted...in retrospect most of that tech time was due to getting licenses going again after ummmm a lapse.
Technically I'm pretty easy peasy. I have a not ancient well chosen mac, standard peripherals, and I don't try go off grid. For example installing things where they don't belong
MadManDan
Postby Hugh Robjohns » Fri Dec 20, 2019 11:39 am
Test post. Please ignore
Postby ConcertinaChap » Sat Dec 21, 2019 7:37 am
Duly ignored.
ConcertinaChap
Postby rACed2 » Sun Dec 22, 2019 4:25 am
Hugh Robjohns wrote:Test post. Please ignore
But I don’t want to ignore it :wave:
rACed2
Organ, synth’s x2 Not enough time or talent.
Postby G-Doubleyou » Tue Dec 24, 2019 2:13 am
Logic is the best bang for the buck, It's been Apple-ized and is far easier to learn than in the past.
All updates have been free for nearly a decade.
G-Doubleyou
G-Dub Studio G-fx 2011 15inch 2.0GHz quad-core i7 Macbook Pro, LPX 10.3.2
2.3 GHz quad-core i7 Mini
Postby AndyN » Tue Dec 24, 2019 12:30 pm
Not sure if this is muddying the waters but Christian Henson has just put up a video of how he works in logic and exports to protools. Logic and Cubase are fairly similar. The video is about writing to picture but gives a useful insight into the benefits of using both
AndyN
Postby MadManDan » Sun Dec 29, 2019 4:52 pm
test
MadManDan
Postby MadManDan » Sun Dec 29, 2019 4:53 pm
test
MadManDan
Postby MadManDan » Sun Dec 29, 2019 5:29 pm
Sorry. Another test. Trying to root out posting problem
MadManDan
Postby MadManDan » Tue Dec 31, 2019 9:25 pm
So many problems posting...so here we go
Now I've had the cubase demo about 10 days. Boy am I scratching my head :headbang:
It looks good tho. Right off the bat I appreciate being able to insert more than one vi on an instrument track. Used t have to mult to do that in pro tools...
The Elf wrote:The trick I've found with PT imports is to just import PT's raw audio files into Cubase, select them all and do a 'Move to Origin'. This places all the audio into the correct relative position. You may find they all jump to somewhere way down the timeline, but once you have the relative positions you can just grab them all once again and place them where you like..
come again? What about all the edits from pro tools?
Also: not quite had enough hands on time to figure out if cubase meets my needs. Looks likely, but want to be sure...When I'm programming straight from editor, as opposed to groove agent, and it's looping around, I'm adding to the beat... Is there an on-the-fly erase button to wipe notes out, drum machine style?
MadManDan
Postby The Elf » Fri Jan 03, 2020 10:38 am
This is just about importing the raw audio files.
Postby Kwackman » Fri Jan 03, 2020 11:16 am
MadManDan wrote:.When I'm programming straight from editor, as opposed to groove agent, and it's looping around, I'm adding to the beat... Is there an on-the-fly erase button to wipe notes out, drum machine style?
I don't know what "drum machine style" means.
The Drum Edit Page can control Groove Agent (although I've never really used it) or any other drum VST like Superior 3 which I think you mentioned before.
You can set up a loop in the Drum editor, you may have to zoom in/out if you want to see all the notes in your loop, depending on the size of your loop.
You can add notes by using the drum stick tool and clicking on the grid at the place you want, as it loops.
To erase the last note you clicked in, you just hit delete.
Or select the eraser tool and just click on any notes you want to delete, while the loop is still running.
There are quantise options that can be applicable as you click, or used afterwards.
I'm not sure if that's the answer to your query, but hopefully it gives you an idea.
Kwackman
Postby MadManDan » Fri Jan 03, 2020 2:49 pm
Thanks kwackman
New update tho. My interface just died. Hopefully I can get the Macs audio out functioning well enough to try this out
MadManDan
Postby MadManDan » Sat Jan 04, 2020 12:35 am
"Drum machine style" refers to working on the fly additively as pattern loops around. In case of a mistake, there is a hard button dedicated to the delete function. Let's say I really don't want that cowbell I played in the second bar. Immediately before it loops around again, I hold down the delete button and the cowbell's midi key until it's wiped.
This is especially important to me as I'm looking to get my unquantized chops together and stay in the moment. No stopping
MadManDan
Postby Kwackman » Sun Jan 05, 2020 12:30 pm
MadManDan wrote:"Drum machine style" refers to working on the fly additively as pattern loops around. In case of a mistake, there is a hard button dedicated to the delete function.
Well, the delete button on the computer keyboard would work, but you need to tell it what to delete...
MadManDan wrote: Let's say I really don't want that cowbell I played in the second bar. Immediately before it loops around again, I hold down the delete button and the cowbell's midi key until it's wiped.
I don't use an external keyboard/pads to make loops, so I don't know for sure.
But, if the last note I added was that cowbell, it will be the highlighted note, so hitting the delete key will wipe it out- all with the loop still running.
Otherwise, you need to select the erase tool and use your mouse to click on the offending cowbell beat. (Again, without stopping the loop running)
It would be best to have a play yourself and see if it works the way you want it to.
There are many options to explore!
Kwackman
Postby MadManDan » Sun Jan 05, 2020 11:56 pm
Thanks again Kwackman.
Eager to try this amidst my tech issues.
Just as I was getting cubase demo, my "sys backup/sd3 lib" drive died. I just got its warranty replacement (bit of a wild goose chase) and recreated the contents when....
My focusrite interface dies. Fml!
So now I have about 10 days to experiment using the Mac's audio out.
I'd imagine it's best to keep it easy and try this with a single instance of halion. Am I right in avoiding anything intensive like superior when using the Mac's audio outs as opposed to my interface or does it make no difference?
Compounding all this is the fact that posting on the forum works maybe 30% of the time. Ahhhh I must laugh. I'm not a real musician/producer/engineer without technical challenges. :headbang:
Just really want to see if cubase does what I need. I'm not investing in anything that doesn't make me happy. Time for more playing less paying
MadManDan
