Mackie desk, Mini Mac and Core Audio
Postby PeteVicary » Thu Dec 19, 2019 1:33 pm
Hi
I am new to this site but I wonder if someone could help me. I currently use a Mackie Onyx 1620i desk with built in audio interface connected to my 10 year old Mac Pro running Logic X via Firewire.
I am going to upgrade my computer in the new year to a top of the range Mac mini. My question is: If I also buy the Apple Thunderbolt to Firewire converter lead to go between the Mac & Mackie, will my computer still automatically recognise the desk as Core Audio. Basically, I really want to continue using my desk.
Regards
Pete
PeteVicary
Re: Mackie desk, Mini Mac and Core Audio
Postby Forum Admin » Thu Dec 19, 2019 2:17 pm
Hi and welcome to SOS Forum.
The definitive answer on this would probably come from forum member desmond but your new Mac Mini would come with the latest macOS (Catalina) installed.
As far as I am aware, the Thunderbolt to Firewire adapter will still work fine under Catalina, and if the Mackie is indeed using Core Audio (and not a dedicated driver), your new Mac Mini should recognise it as an interface.
SEARCH 12,352 SOS Reviews/Techniques articles: www.soundonsound.com/search
Postby zenguitar » Thu Dec 19, 2019 2:31 pm
You need to check on the Mackie site. Support for earlier generations of their FireWire devices stopped several versions of Mac OS back. They have a handy table on their support pages listing driver support for each model and OS’s.
liberté, frivolité et vanité
Postby fatbenelton » Thu Dec 19, 2019 3:39 pm
I thought the onyx drivers had been abandoned too so defo worth checking.
fatbenelton
Jonny
Postby ConcertinaChap » Thu Dec 19, 2019 3:41 pm
If the Onyx is a class compliant device (i.e. doesn't need specific drivers to be installed) I should have thought it would work without any issue.
Edit: just had a look at the manual for the 1620i and it says "Mac OS X contains built-in drivers, so no software installation is required". So I think you're home and dry.
ConcertinaChap
Intergalactic Mercurial Man of Mystery.
Postby Forum Admin » Thu Dec 19, 2019 4:42 pm
ConcertinaChap wrote:Edit: just had a look at the manual for the 1620i and it says "Mac OS X contains built-in drivers, so no software installation is required". So I think you're home and dry.
That's what I was trying to say. :)
Postby slouchedoverogre » Sat May 09, 2020 1:59 am
did it work? i just got an onyx 1620 with the firewire card and got the firewire to thunderbolt adapter , but the computer doesnt see the interface.
IM SAD!
slouchedoverogre
Postby al_diablo » Tue May 12, 2020 3:20 pm
As I understand it- There are 2 variants of the mackie desk. One has serial numbers starting with 204 and is class compliant, the other with 003 and is not.
I've read reports from people who are using the 204 serial number models with thunderbolt adapters and no issue.
I bought one second hand hoping to get firewire working but although it works perfectly as a mixer it doesnt show up as an interface. The previous owner had the same issue so I think my particular one that has a broken firewire card.
al_diablo
Postby jrags » Thu May 21, 2020 12:25 am
slouchedoverogre wrote:did it work? i just got an onyx 1620 with the firewire card and got the firewire to thunderbolt adapter , but the computer doesnt see the interface.
IM SAD!
What adaptor did you get to convert firewire 400 to thunderbolt? I've got a 003 serial number and want to give it a shot, but I can't even find an adapter.
I also found this knowledgebase article, but reading it seems to think that the 003 serial number is the newer model.
jrags
Postby jrags » Thu May 21, 2020 6:05 am
I actually did it. Here's the gear flow:
Mackie 1220i (30 serial number)
--> Firewire 800 to 400 cable
--> Other World Computing Thunderbolt 2 Dock
--> Thunderbolt 2 cable
--> iMac 2015 running MacOS 10.15 Catalina
Audio goes in and out of the computer and mixer just fine. No drivers or software hacks needed!
jrags
Postby emphor » Fri Dec 25, 2020 4:54 am
For the record (and in case anyone else spends three days searching the internet for the answer), I have successfully connected my Mackie ONYX 1220i (serial number starting with 204) via FireWire to my 2012 iMac running 10.15.7 (Catalina - via external USB drive).
The set-up:
• FireWire 400 cable to Sonnet FireWire 400 to 800 adapter
• Sonnet FireWire 400 to 800 adapter to Apple FireWire 800 to Thunderbolt adapter
• Thunderbolt adapter to iMac
THE KEY INGREDIENT was downloading the "Onyx I Drivers 016_Onyx_820i_1220i_1620i_1640i Setup" from Mackie https://supportloudtech.netx.net/loud-public/#/asset/17482. After this was installed my Mackie appeared as an inout / output device.
Cheers, Matt
emphor
