Adding external drives to mac mini thunderbolt port?
Postby Kwackman » Sat Mar 21, 2020 5:59 pm
I recently bought a used 2012 mac mini.
I’m hoping to add at least one external SSD drive to it, for sample libraries etc.
It has one thunderbolt port. It just says Thunderbolt, so I’m guessing it’s Thunderbolt 1, not 2 or 3.
What’s the best way to add drives?
I was thinking of maybe a caddy of some sort that I could drop or plug SSD drives into.
When I google thunderbolt caddies, I seem to get USB3 devices, which seems to use the same connector.
Open to ideas….
Thanks.
This is the model of mac mini if it helps.
https://everymac.com/systems/apple/mac_ ... specs.html
Kwackman
Re: Adding external drives to mac mini thunderbolt port?
Postby ConcertinaChap » Sun Mar 22, 2020 12:04 am
I have one of those, I keep it as a spare nowadays but it was my main machine for a few years. Decent machine. It's definitely Tbolt 1 with a displayport type connector. I don't recall seeing any SSDs with Tbolt 1 or 2 ports, only Tbolt 3 at wincingly expensive prices.
The USB ports are all USB 3.0 which is reasonably brisk so I'd settle for that with something like this, maybe.
ConcertinaChap
We are normal and we want our freedom!.
Postby Sam Spoons » Sun Mar 22, 2020 1:47 am
Yup, I have 2011 and 2012 MBPs and would certainly give a SATA SSD in a USB3 caddy a try, I have a couple and they perform pretty well though I don't use them in the same way as you are suggesting.
Postby Kwackman » Mon Mar 23, 2020 3:43 pm
Thanks for your replies.
They made me explore a bit more, and discover was wrong thinking that USB3 and Thunderbolt use the same connector. :headbang:
So, as you've already pointed out, thunderbolt1 caddies aren't out there!
I'd like to use the Thunderbolt 1 port, as the 4 USB ports are already being used.
So, how would I go about adding a SSD drive to this port?
I'm guessing this would need a Thunderbolt 1 - to USB adaptor cable? Then buy an SSD drive with a USB connector, which seem easier to track down.
If my logic is wrong (again!) or there are better solutions, I'd be very happy to take advice.
Thanks.
Kwackman
Postby Guido3 » Mon Mar 23, 2020 3:48 pm
I'm not familiar with the MacMini you have. Does it have a Superdrive? If so, you could remove this and replace it with an internal SSD of your choice. I did this with an old MBP off mine. You can get the kit from Amazon for around £25. This includes a USB caddy for the Superdrive so you can still use it when required.
2.5" internal SSD's can be had pretty cheap nowadays so why not replace the system drive with a SSD whilst you at it. I had a 512GB system SSD and a 1TB SSD internal sample drive and the machine flew!!
You could probably do all this for around £200.
Guido3
And Bagpuss, once he was asleep, was just a saggy old cloth cat.
Postby ConcertinaChap » Mon Mar 23, 2020 5:11 pm
You could get docking stations that plugged into the Tbolt port and gave you a range of extra ports. I've got a Belkin one that gives ethernet, firewire, 3 x USB 3 ports and an extra Tbolt port for daisy chaining. They're no longer made but you might find one second hand.
ConcertinaChap
Postby Kwackman » Mon Mar 23, 2020 5:53 pm
Thanks Guido, there isn't an optical drive in this machine, but for this workflow I prefer an external drive. Thanks anyway.
Thanks CC, I'll have a look for one of those docking stations. :thumbup:
Kwackman
Postby ConcertinaChap » Mon Mar 23, 2020 7:11 pm
If you see a Tbolt 2 version that will work just fine with a Tbolt 1 port. 1 and 2 are almost the same except that T1 had 2 channels whereas T2 aggregated them into one double speed channel to support very high resolution screens. They have the same displayport connector and use the same cable.
ConcertinaChap
Postby James Perrett » Mon Mar 23, 2020 11:46 pm
I would have thought that a Thunderbolt to SATA convertor would be most appropriate for an external SSD.
Postby ConcertinaChap » Tue Mar 24, 2020 12:06 am
ConcertinaChap
Postby Kwackman » Thu Apr 02, 2020 5:08 pm
Thanks for the replies and advice.
I ended up going down a different route and bought an Anker USB3 hub which plugs into one of the USB ports on the mac mini. The hub has 4 USB sockets. That frees up one (more if required) USB3 port on the mac mini, and I'll add a USB3 drive that way.
It means I still have the Thunderbolt 1 port free if I decide, for example, to add another screen in the future.
Thanks again for the knowledge and ideas given.
Kwackman
Postby ConcertinaChap » Thu Apr 02, 2020 10:53 pm
That sounds thoroughly sensible.
ConcertinaChap
