Using zoom h6 on iPhone 11 video
Postby raspyramon » Tue Apr 07, 2020 9:59 am
Hello everybody
I m new here
I’ using normally my zoom h6 as a 4 entry recorder
I m actually stuck in Sri Lanka for at least a month
And I want to record some video where I m singing and play guitar , using the h6 for the sound
I don’t have any computer or other material here
The non-essential shop are closed
So I have to do which what I have here
I ve tried this:
I have a female/female USB adapter so I plugged the mini usb on the zoom then the adapter then the original usb/lightening cable to my iPhone
I went in the menu select usb interface/ iPad and put the monitor on
But nothing
Did I forgot something?
Thanks for your answer
It will be helpful
Cheers
raspyramon
Re: Using zoom h6 on iPhone 11 video
Postby s_e_a_n » Tue Apr 07, 2020 7:14 pm
Have you got AUM or another DAW that allows you to select audio inputs?
s_e_a_n
Programmer, sound engineer, artist, musician
Postby The Elf » Tue Apr 07, 2020 7:18 pm
You need to be running a DAW app.
Postby CS70 » Tue Apr 07, 2020 8:01 pm
I think you need the camera connection kit? Maybe it's possible to buy one also in Sri Lanka?
An alternative would be to record separately video and audio and then rejoining on a phone video editing app, but you need someway to get the sound out of the Zoom after recorded and without a computer I guess that's tricky.
Another way is to use a DSLR camera which have both a line input and a wireless control from the phone (for example, my Panasonic Lumix cameras can). The DLSR would record the video using the audio from the zoom, and the you can move the video from the camera to the phone wirelessly via the app - and edit on the iPad..
Postby Sam Spoons » Tue Apr 07, 2020 11:38 pm
Yes, the iPhone and the Zoom are both 'slave' devices, the camera kit allows the iPhone to work as a 'host'. Simply using a F-F USB connector will not work.
Postby raspyramon » Wed Apr 08, 2020 8:23 am
Ok thank you for your answers
I was following the instructions of this guy
He don t use any DAW
It s on the zoom h5 with iPhone 6
https://m.youtube.com/watch?v=N2LzinHsE ... e=youtu.be
So is it the kit you’re talking about ?
Thanks again for helping me
raspyramon
Postby Sam Spoons » Wed Apr 08, 2020 11:20 am
Yes, that's the cable. That vid covers all the detail, if you just follow those instructions you should be fine. I assume you are recording video on the iPhone? If so you don't need a DAW.
Postby The Elf » Wed Apr 08, 2020 12:12 pm
I'd get one of the connectors with a lightning power inlet as well.
And get a genuine Apple one - the others rarely work properly.
You will need a DAW to multi-track.
