Logic Pro X 10.5 is out!
Postby desmond » Tue May 12, 2020 12:56 pm
Ooh yeah!!
Live loops, Sampler, Quick Sampler, Step Sequencer, Drum Synth, more content...
Requires Mojave, as I expected, so it's a no go for me... :(
On your AppStore now...
Re: Logic Pro X 10.5 is out!
Postby IAA » Tue May 12, 2020 1:46 pm
My App Store can't see it yet? :roll:
EDIT - Oh yes it can!!!
Looking forward to the sampler updates -
IAA
Postby desmond » Tue May 12, 2020 1:52 pm
Press Release: "Apple unveils biggest update to Logic since the launch of Logic Pro X"
https://www.apple.com/newsroom/2020/05/ ... gic-pro-x/
Live Loops
• Compose music by arranging and triggering cells in a grid using loops, samples, and your recordings
• Perform and capture freeform arrangement ideas into the tracks area
• Add Remix FX to perform creative effects like filters, gates, repeaters, and bitcrusher
• Use Logic Remote on your iPad or iPhone to perform Live Loops and Remix FX using Multi-Touch gestures to trigger several loops or effects simultaneously
Sampler
• Create and edit sophisticated multi-sampled instruments using a drag and drop workflow
• New modern design provides synthesis, mapping, and zone editing in a single window interface
• Integrated zone editor offers detailed control over start, end and loop points
• Mapping editor enables fast and flexible assignment of samples across the keyboard
• Flex Time has been integrated into Sampler allowing sounds to be played at the same length, regardless of pitch
• Auto Sampler automates the process of converting MIDI-enabled hardware and software instruments into Sampler instruments
• Supports all existing EXS24 instruments
Quick Sampler
• Import a single audio file to instantly build a playable sampled instrument
• Quick Sampler automatically identifies the root note, optimal loop points, and matches your project tempo
• Use Slice mode to chop a vocal or drum sample into multiple slices that can be triggered on a keyboard
• Record live samples using a microphone, external hardware, or from any track or bus
Drum Machine Designer
• Use Drum Machine Designer to build custom drum kits by dragging and organizing samples
• Directly access Quick Sampler or Drum Synth controls on any pad
• Easily assign any instrument or third-party plug-in to a pad
• Perform any sound chromatically to create bass lines or other melodic parts
Step Sequencer
• Build your own beats, melodies and effect automation using an interface inspired by classic drum machine workflows
• Create and edit patterns with discrete control over velocity, repeat, chance, offset, step rate, skip and tie for each row
• Use any patch as a sound source, including custom kits made with Quick Sampler and Drum Machine Designer
• Includes a library of over 150 rhythmic and melodic patterns
More Content
• Over 2,500 new loops in a variety of instruments and genres covering modern and classic hip-hop, electro house, reggaeton, future bass, techno, and transition effects
• 17 Live Loops starter grids covering a range of electronic and hip-hop genres
• More than 70 new Drum Machine Designer kits
• Over 1,500 new patches
• Original multi-track project of Billie Eilish “Ocean Eyes”
Additional Features
• The Drum Synth plug-in generates synthesized kicks, snares, toms, and hi-hats with dedicated sound shaping controls
• Individual or multiple audio files or software instrument regions can be dragged into an empty track header to provide instant options for creating Sampler, Quick Sampler, Drum Machine Designer, or Alchemy instruments
• Multiple additional enhancements and stability improvements
Postby ConcertinaChap » Tue May 12, 2020 2:07 pm
As primarily a sound recordist I don't think there's much here for me. Nevertheless I'll install it and will be happy to be proved wrong on this :)
ConcertinaChap
Postby desmond » Tue May 12, 2020 2:11 pm
Postby desmond » Tue May 12, 2020 2:14 pm
ConcertinaChap wrote:As primarily a sound recordist I don't think there's much here for me. Nevertheless I'll install it and will be happy to be proved wrong on this :)
Don't forget that there will be *lots* of small improvements over the headline features. For example, things like there is now a key command to bypass all plugins on the selected channel. Some of these small things are just as awesome in practical use as the bigger toys...
Postby ConcertinaChap » Tue May 12, 2020 2:20 pm
I see what you mean! That's quite a list. I can use that particular minor enhancement definitely.
ConcertinaChap
Postby brucie » Tue May 12, 2020 2:30 pm
There is some good news out there!
That is pretty epic, especially the upgrade to EXS24 (finally!)
Happy happy days!!
brucie
Neil S. Bruce - http://www.spencerbruce.com
Postby fatbenelton » Tue May 12, 2020 4:27 pm
And Apple are to be applauded for not fleecing their existing customer's for more money. That's several large updates for free. In the same period I would've spent a few hundred quid upgrading via every iteration of Cubase from 7 to 10.5.
fatbenelton
Jonny
Postby IAA » Tue May 12, 2020 5:07 pm
. That’s a great addition yippee!
IAA
Postby Ian Shaw » Tue May 12, 2020 5:39 pm
fatbenelton wrote:And Apple are to be applauded for not fleecing their existing customer's for more money. That's several large updates for free. In the same period I would've spent a few hundred quid upgrading via every iteration of Cubase from 7 to 10.5.
Wow! I can't remember the last time I paid for Logic upgrade. It's 10.5 turned up to 11! Been fiddling with Bitwig lately which has some great features. Looks like Apple have been copping an eye in that direction. This is going to tempt me back again.
Well done Apple (not something that's often said these days!)
Ian Shaw
Sent by carrier pigeon
Postby Humble Bee » Tue May 12, 2020 6:44 pm
Great update! And free! :thumbup:
Just saw that its still $199. That is hard to beat with all the goodness that comes with it...
Humble Bee
Postby Ian Shaw » Tue May 12, 2020 7:15 pm
Just triggering some loops & playing the remix fx from my phone - it's a blast! Not sure if it's any use in real life, but hey, the new samplers are a great addition.
Ian Shaw
Postby Dan LB » Wed May 13, 2020 12:01 am
brucie wrote:There is some good news out there!
Happy happy days!!
Absolutely!! Now let's hope that they update the UI for all the other awkward looking virtual instruments!
Loving the new Quick Sampler. It's an absolute banger! :clap:
Dan LB
Postby Dan LB » Wed May 13, 2020 12:03 am
Humble Bee wrote:Great update! And free! :thumbup:
For me, Logic is the bargain of the century! An absolute no-brainer. I have composed so much more music since I made the switch from Pro Tools (I still use PT regularly but just not for composition anymore)
Dan LB
