Logic 10.5.1 is out
Logic 10.5.1 is out
PostPosted: Fri Jun 12, 2020 8:15 am
by rACed2
Extensive bug fix list and apparently some new sounds.
Re: Logic 10.5.1 is out
PostPosted: Fri Jun 12, 2020 10:44 am
by desmond
Quite a few expected fixes in this one:
https://support.apple.com/en-us/HT203718
PostPosted: Fri Jun 12, 2020 1:17 pm
by Ian Shaw
Unfortunately, I'm getting a lock up on start up & have to force quit. seems to be Waveshells AU causing the problem as once they are removed it starts up fine
Ian
PostPosted: Fri Jun 12, 2020 1:21 pm
by Ian Shaw
Ian Shaw wrote:Unfortunately, I'm getting a lock up on start up & have to force quit. seems to be Waveshells AU causing the problem as once they are removed it starts up fine
Ian
Strange. I put them back, did a restart & all is fine now
PostPosted: Fri Jun 12, 2020 1:57 pm
by desmond
On first launch, 10.5.1 does an extended plugin scan (presumably to fix issues caused in the earlier version AU scan to do with multiple outputs etc), so it might take a few minutes to loop through all your plugins.
Once that's done, it's quicker to launch again.
