Subwoofer only connection
Postby Sanjeev Srivastav » Mon Jul 13, 2020 8:14 pm
Can I connect just a subwoofer (no speakers) to my Macbook Air. I tried it with RCA cable to the headphone jack but just got the faint sound from the subwoofer at the highest volume. Also connected it thru audio interface but the result is same.
Sanjeev Srivastav
Re: Subwoofer only connection
Postby blinddrew » Mon Jul 13, 2020 9:13 pm
What kind of subwoofer do you have?
Postby monospace » Mon Jul 13, 2020 9:14 pm
Pretty sure you are going to need an amp to drive your subwoofer.
Something like this:
https://www.amazon.com/gp/product/B07L4 ... UTF8&psc=1
monospace
Postby Hugh Robjohns » Mon Jul 13, 2020 9:19 pm
Sanjeev Srivastav wrote:Can I connect just a subwoofer (no speakers) to my Macbook Air.
Yes... Probably.
You just need to make sure the output level and connection format of the Mac's headphone socket is compatible with the input Level and connection format of the subwoofer.
I can't help you with that as you've not provided any information about the sunwoofer. Are you sure the sub's input is line level?
The headphone socket is stereo and an RCA plug is mono... Or was it a dual-RCA cable?
Of course, a sub only reproduces the lowest octave, so you'd need some material that had some decent low end content...
Postby Sanjeev Srivastav » Mon Jul 13, 2020 11:07 pm
blinddrew wrote:What kind of subwoofer do you have?
Its NICOLE Amplified Speaker System (FP9903) 20W.
Sanjeev Srivastav
Postby Sanjeev Srivastav » Mon Jul 13, 2020 11:15 pm
monospace wrote:Pretty sure you are going to need an amp to drive your subwoofer.
Written on the subwoofer-" Amplified stereo system". Do I still need an amplifier.
Sanjeev Srivastav
Postby Sanjeev Srivastav » Mon Jul 13, 2020 11:24 pm
Its a NICOLE Amplified Speaker System Subwoofer(FP9903) 20 W, with only a power button and 2 white and 2 Red female sockets in the back saying 'INPUT'. I used 3.5mm to 2-Male RCA Adapter Cable.
Sanjeev Srivastav
Postby monospace » Mon Jul 13, 2020 11:57 pm
If you're using ONLY the subwoofer and not the rest of this "amplified stereo system" (which presumably contains the amp to drive said subwoofer) then yes, you most likely will need an amp.
monospace
Postby blinddrew » Tue Jul 14, 2020 12:36 pm
If it's a sub-satellite system then the amp is more likely to be in the sub.
I can't find any detail on the model so if the OP could post a link to a manual or even a couple of photos that would help.
Postby Sanjeev Srivastav » Tue Jul 14, 2020 2:27 pm
blinddrew wrote:If it's a sub-satellite system then the amp is more likely to be in the sub.
[img
Sorry so new to this forum..Can you please tell me how to upload a photo here.
Sanjeev Srivastav
Postby Sam Spoons » Tue Jul 14, 2020 2:40 pm
The forum doesn't host images so you need to use something like imgur and use the appropriate link.
