Subwoofer only connection
PostPosted: Mon Jul 13, 2020 8:14 pm
by Sanjeev Srivastav
Can I connect just a subwoofer (no speakers) to my Macbook Air. I tried it with RCA cable to the headphone jack but just got the faint sound from the subwoofer at the highest volume. Also connected it thru audio interface but the result is same.
Re: Subwoofer only connection
PostPosted: Mon Jul 13, 2020 9:13 pm
by blinddrew
What kind of subwoofer do you have?
PostPosted: Mon Jul 13, 2020 9:14 pm
by monospace
Pretty sure you are going to need an amp to drive your subwoofer.
Something like this:
https://www.amazon.com/gp/product/B07L4 ... UTF8&psc=1
PostPosted: Mon Jul 13, 2020 9:19 pm
Sanjeev Srivastav wrote:Can I connect just a subwoofer (no speakers) to my Macbook Air.
Yes... Probably.
You just need to make sure the output level and connection format of the Mac's headphone socket is compatible with the input Level and connection format of the subwoofer.
I can't help you with that as you've not provided any information about the sunwoofer. Are you sure the sub's input is line level?
The headphone socket is stereo and an RCA plug is mono... Or was it a dual-RCA cable?
Of course, a sub only reproduces the lowest octave, so you'd need some material that had some decent low end content...
PostPosted: Mon Jul 13, 2020 11:07 pm
blinddrew wrote:What kind of subwoofer do you have?
Its NICOLE Amplified Speaker System (FP9903) 20W.
PostPosted: Mon Jul 13, 2020 11:15 pm
monospace wrote:Pretty sure you are going to need an amp to drive your subwoofer.
Written on the subwoofer-" Amplified stereo system". Do I still need an amplifier.
PostPosted: Mon Jul 13, 2020 11:24 pm
Its a NICOLE Amplified Speaker System Subwoofer(FP9903) 20 W, with only a power button and 2 white and 2 Red female sockets in the back saying 'INPUT'. I used 3.5mm to 2-Male RCA Adapter Cable.
PostPosted: Mon Jul 13, 2020 11:57 pm
by monospace
If you're using ONLY the subwoofer and not the rest of this "amplified stereo system" (which presumably contains the amp to drive said subwoofer) then yes, you most likely will need an amp.
PostPosted: Tue Jul 14, 2020 12:36 pm
by blinddrew
If it's a sub-satellite system then the amp is more likely to be in the sub.
I can't find any detail on the model so if the OP could post a link to a manual or even a couple of photos that would help.
PostPosted: Tue Jul 14, 2020 2:27 pm
blinddrew wrote:If it's a sub-satellite system then the amp is more likely to be in the sub.
[img
Sorry so new to this forum..Can you please tell me how to upload a photo here.
PostPosted: Tue Jul 14, 2020 2:40 pm
The forum doesn't host images so you need to use something like imgur and use the appropriate link.
