How to install Waves v9 plugin on macOS Catalina
Postby dbfs » Fri Nov 27, 2020 5:16 pm
Hi Folks,
I had to install a new HDD on my system and I went with Catalina.
Not wanting to pay waves $240 for the Waves Update Plan, I came across this article.
https://denivel.blogspot.com/2019/12/ho ... macos.html
I was just wondering if anyone here had tried this type of approach or if it looks suspect.
Might this be a solution?
dbfs
dbfs
Re: How to install Waves v9 plugin on macOS Catalina
Postby desmond » Fri Nov 27, 2020 5:28 pm
It's only a solution if it works. ;)
All it's really doing is changing the files that tell the installer whether your OS qualifies for installing it or not - it doesn't say anything about whether those plugin versions do actually work on your system.
If you want to try, give it a try. Make backups before you start.
desmond
Postby dbfs » Fri Nov 27, 2020 10:25 pm
Hi Desmond,
I backed up and tried it and it worked. Very happy.
This might help some other folk if they are wondering.
dbfs
dbfs
Postby acousticdonk » Sat Dec 26, 2020 10:00 pm
the link above is no longer there is there directions somewhere else?
acousticdonk
Postby desmond » Sun Dec 27, 2020 12:57 am
When a page no longer exists, the first thing you should think to try is to Wayback Machine that URL.
https://web.archive.org/web/20201109041616/https://denivel.blogspot.com/2019/12/how-to-install-waves-v9-plugin-on-macos.html
desmond
Postby Jadoube » Mon Jan 25, 2021 11:35 pm
Ah yes... I am going to try this again. Waves. Enough said.
Thanks for the post!
Jadoube
_________
David
