Sam Spoons wrote:Cost? :blush:
Precisely. So simple a task should be in the OS. Or so I thought.
OK, although I'm pretty sure the inter track spacing can be adjusted, and track titles etc will be written to the CD. You got me on the ISRC though!ConcertinaChap wrote:You're missing two things: CD-text (including such esoterica as ISRC codes) and inter-track spacing.
CS70 wrote:Just in case I was too cryptic, Nero is the name of a software which used to be one of the go-to when ripping was common. Once you have an ISO image you should be able to burn it directly on another disk.
Ah... :beamup:James Perrett wrote:CC is on a Mac.
paul tha other wrote:i wasnt sure...its been years since i did any cd stuff..now that i think about it i think waveburner's ddp stuff was flakey.
its all a fuzzy memory now
