Last night a lot of popups popped up just before bedtime, and I closed them all a little rapidly I think. One of them must have been the dreaded Update request/threat because this morning it says Update in Progress 48 minutes left.
desmond wrote:As long as you have backup clones of your system drive, you're always covered if something catastrophic should happen to your system.
Failing that, Time Machine should also let you restore, though I don't personally use it, so ymmv.
I'm sure you can google a way to turn update reminders off, too, to avoid this happening in the future.
desmond wrote:It updated to Mojave?
Or was it just security updates for HS or something?
Anyway, glad nothing bad happened! (For once!)
desmond wrote:You bought a computer that can't run Catalina that came with Catalina?
How does that work?![]()
If it's a patched Catalina to work on a non-Metal supporting Mac, then yes, you will get crashes when stuff ties to use Metal it assumes to be there, as all machines that support Catalina support Metal.
desmond wrote:Ah, yes it was just security updates, not an OS update.
These are almost certainly completely unlikely to change or break any of your software, you can usually do these safely enough and not only are they not to be worried about, they are usually recommended.
ConcertinaChap wrote:I presume what you mean is System Preferences / Software Update which will currently be showing the OS upgrade, whatever that is. If there are other security updates available for Mojave (and I expect there would be because the one I described above only came out a few weeks ago) then these will show as "another update is available. More info". If you click on More info then it opens a window that, well, gives you more info but it also lets you do that update only without triggering the full OS upgrade.
