Your Recommended FireWire Adaptor Cards
Re: Focusrite Saphire 10 I/O
Postby Hypagen » Tue Jul 07, 2009 10:57 am
javier53 wrote:How is better devices USB or devices PCI?
Thanks.
The Focusrite Saphire only connects via Firewire 400.
Hypagen
Re: Your Recommended FireWire Adaptor Cards
Postby Martin Walker » Wed Jul 08, 2009 5:15 pm
boofy - I thought your queries on the Sapphire were better put in a separate thread to keep this one on track. Here's the new thread I set up for you:
www.soundonsound.com/forum/showflat.php ... ber=751082
Postby studer58 » Thu Jul 16, 2009 2:12 am
Hi everyone, and apologies for (somewhat) sidetracking this thread with my question...I moved it here because it seemed a little more relevant in this section than in the general PC sub-forum ? I'd love to contribute my findings here, but first I need to determine which type of card I should get, as my new (but old !) laptop has both ! Like Drongoloid I have an Audiofire 8 which is prone to random FW dropouts when using Reaper, and by dropouts I mean complete loss of FW connectivity, requiring a complete interface reboot and re-starting Reaper (an infuriating exercise when recording a one-off orchestral concert with no chance of 're-runs' !!) Hence my question below. As soon as I've obtained a card I'll report back here with findings.
I'll be getting an older IBM/Lenovo Thinkpad T43 soon, for mobile recording duties using an Echo Audiofire 8 interface. The Thinkpad doesn't have onboard Firewire at all, but DOES have both a Cardbus type 2 (PCMCIA) slot and an ExpressCard slot. Which type of (TI chipset, of course) Firewire adapter card should I get for use with the Audiofire...the Cardbus or the Express version ? Is it true that there are data bandwidth/speed limitations with Cardbus that aren't there with Express Card, as this might become significant if I'm recording at say 24/96 over 6 to 8 inputs at once ?
Thanks for your advice,
Ray
studer58
Postby joakes » Thu Aug 27, 2009 11:50 am
1) Firewire Audio Device : PreSonus FS 26x26
2) Adapter : LaCie Firewire 400
3) Card Format : PCI 3x400
4) Chipset : TI TSB43AB23 1394A-2000
5) Rating : 5 (solved problems for me that I had with the on-board A&T Lucent adapter.
Cheers,
Jerry
joakes
Postby GlennKay » Thu Nov 12, 2009 10:17 am
I can pass on the name of one that did not work for me, the StarTech 2-Port PCI-Express card. The firewire chip is the JMicron JM381.
Apparently some more-or-less current PC motherboards comes with JMicron SATA controllers that are problematic in terms of hard drive throughput.
On my DAW, the StarTech Firewire card resulted in pops and crackles when connected to a Liquid Mix, and there was no Firewire connection at all with a Saffire (Pro 26 i/o).
For some reason, here in Toronto, it's like looking for hen's teeth trying to locate Belkin, Siig, Lacie PCIe Firewire400 cards. I've tried literally a dozen computer and music stores with no luck so far, same with some of the web retailers.
Regards
Glenn
GlennKay
"The path of excess leads also to the palace of wisdom....but they let you in through the back door."
Postby GlennKay » Sun Nov 15, 2009 4:35 pm
Greetings Part 2:
I replaced the StarTech firewire card from my previous post with a Siig NN-E20012-S2 (Firewire 400, 2 ports, PCIe). It works perfectly with my Saffire Pro 26 i/o.
The firewire chip on this card is Texas Instruments. One thing i noticed, unlike with the Start Tech product, this card has a a plug into which to connect a lead from the power supply -- makes total sense for a device needing a powered firewire bus.
Regards
Glenn
GlennKay
Postby vegas71 » Tue Nov 24, 2009 12:38 pm
As with OneWorld i bought just a cheapo firewire card and it works fine (i suppose i got lucky, i'm not too sure of the make, although i seem to remember i bought it from PC World, and the only one they appear to sell is made by Dynamode?)
1. FireWire Audio Device: : Edirol FA-66
2. Adaptor Make & Model: possibly Dynamode?
3. Card Format & Ports: PCI, 3
4. Adaptor Controller: VIA OHCI Compliant IEEE 1394 Host Controller
5. Rating: Good
As this works absolutely perfectly with my Edirol FA-66, if i was to buy a new pc, could i just take this out of my current pc and put it in my new one, and have it continue to work well, or is there other factors to consider?
David
vegas71
Postby Marc 'Kundalini' » Tue Dec 01, 2009 4:07 pm
Hi guys
I'm planning a Windows 7 PC DAW to incorporate my new MOTU Ultralite Mk3. I'll probably go with the Intel I7 860 or 920.
Any suggestions on a good combination of motherboard & PCI-FW card?
Marc 'Kundalini'
Postby basic channel » Sun Dec 13, 2009 1:34 pm
1. FireWire Audio Device: Powercore Firewire
2. Adaptor Make & Model: ST Labs 2:1, from Maplins:
http://www.maplin.co.uk/Module.aspx?ModuleNo=221528#Faq
3. Card Format & Ports: PCI Express, 2x 400 External, 1x 400 internal
4. Adaptor Controller: Texas Instruments
5. Rating: Excellent (so far - all crashes experienced with onboard Agere chip (Asus P5KE) have disappeared)
basic channel
Postby Martin Walker » Mon Dec 14, 2009 6:55 pm
Marc 'Kundalini' wrote:Hi guys
Hi Marc,
And welcome to the SOS Forums! 8-)
As you'll notice if you read the existing contents of this thread, it's the combination of Firewire card and audio interface that's important, rather than FW card and motherboard.
Postby mjfe2 » Tue Jan 05, 2010 10:10 pm
hi, just wanted to hijack this thread to ask about my mackie onyx 400f which i use with a blekin firewire pci port attached to an old pentium 4 beast (512mb RAM).
the latency in cubase reads 11 ms input and 20 ms output latency -- is this a generally acceptable length?
cheers!
mjfe2
Postby kenwyn » Mon Feb 22, 2010 4:46 pm
Hi Guys
So I want to buy one of these cards and I am finding it hard to find a place to buy. I went to this site
http://www.stuff-uk.net/c-1384-firewire-cards.aspx
They start at 6 then go to 94 pounds. The maplin one quoted above is out of stock at the moment. Anyone have a link for any others already reviewed above.
kenwyn
P.S.
Would rather pay 6 pounds if poss :)
kenwyn
Postby kenwyn » Mon Feb 22, 2010 4:55 pm
Thought I would post this link with the recommendations for the Focusrite range,
http://www.focusrite.com/answerbase/en/var/attachments/Focusrite_IEEE_1394_compatibility.pdf
kenwyn
Postby Basari Studios » Mon Jul 26, 2010 4:24 pm
Interface: TC Impakt Twin
FW Controller: SIIG; http://www.bhphotovideo.com/c/product/629062-REG/SIIG_NN_E38012_S3_FireWire_800_PCI_Express_x1.html
Chipset:TI XIO2213
Rating: EXCELENT!!!
Never had anything better in my life or any better configuration.
Working on 128 BS, no clicks, no dropouts, freezes or anything at all.
Basari Studios
10900k. ASUS Pro Art Z490
