Your Recommended FireWire Adaptor Cards
Re: Your Recommended FireWire Adaptor Cards
Postby GlennKay » Sun Nov 15, 2009 4:35 pm
Greetings Part 2:
I replaced the StarTech firewire card from my previous post with a Siig NN-E20012-S2 (Firewire 400, 2 ports, PCIe). It works perfectly with my Saffire Pro 26 i/o.
The firewire chip on this card is Texas Instruments. One thing i noticed, unlike with the Start Tech product, this card has a a plug into which to connect a lead from the power supply -- makes total sense for a device needing a powered firewire bus.
Regards
Glenn
GlennKay
"The path of excess leads also to the palace of wisdom....but they let you in through the back door."
Postby vegas71 » Tue Nov 24, 2009 12:38 pm
As with OneWorld i bought just a cheapo firewire card and it works fine (i suppose i got lucky, i'm not too sure of the make, although i seem to remember i bought it from PC World, and the only one they appear to sell is made by Dynamode?)
1. FireWire Audio Device: : Edirol FA-66
2. Adaptor Make & Model: possibly Dynamode?
3. Card Format & Ports: PCI, 3
4. Adaptor Controller: VIA OHCI Compliant IEEE 1394 Host Controller
5. Rating: Good
As this works absolutely perfectly with my Edirol FA-66, if i was to buy a new pc, could i just take this out of my current pc and put it in my new one, and have it continue to work well, or is there other factors to consider?
David
vegas71
Postby Marc 'Kundalini' » Tue Dec 01, 2009 4:07 pm
Hi guys
I'm planning a Windows 7 PC DAW to incorporate my new MOTU Ultralite Mk3. I'll probably go with the Intel I7 860 or 920.
Any suggestions on a good combination of motherboard & PCI-FW card?
Marc 'Kundalini'
Postby basic channel » Sun Dec 13, 2009 1:34 pm
1. FireWire Audio Device: Powercore Firewire
2. Adaptor Make & Model: ST Labs 2:1, from Maplins:
http://www.maplin.co.uk/Module.aspx?ModuleNo=221528#Faq
3. Card Format & Ports: PCI Express, 2x 400 External, 1x 400 internal
4. Adaptor Controller: Texas Instruments
5. Rating: Excellent (so far - all crashes experienced with onboard Agere chip (Asus P5KE) have disappeared)
basic channel
Postby Martin Walker » Mon Dec 14, 2009 6:55 pm
Marc 'Kundalini' wrote:Hi guys
Hi Marc,
And welcome to the SOS Forums! 8-)
As you'll notice if you read the existing contents of this thread, it's the combination of Firewire card and audio interface that's important, rather than FW card and motherboard.
Postby mjfe2 » Tue Jan 05, 2010 10:10 pm
hi, just wanted to hijack this thread to ask about my mackie onyx 400f which i use with a blekin firewire pci port attached to an old pentium 4 beast (512mb RAM).
the latency in cubase reads 11 ms input and 20 ms output latency -- is this a generally acceptable length?
cheers!
mjfe2
Postby kenwyn » Mon Feb 22, 2010 4:46 pm
Hi Guys
So I want to buy one of these cards and I am finding it hard to find a place to buy. I went to this site
http://www.stuff-uk.net/c-1384-firewire-cards.aspx
They start at 6 then go to 94 pounds. The maplin one quoted above is out of stock at the moment. Anyone have a link for any others already reviewed above.
kenwyn
P.S.
Would rather pay 6 pounds if poss :)
kenwyn
Postby kenwyn » Mon Feb 22, 2010 4:55 pm
Thought I would post this link with the recommendations for the Focusrite range,
http://www.focusrite.com/answerbase/en/var/attachments/Focusrite_IEEE_1394_compatibility.pdf
kenwyn
Postby Basari Studios » Mon Jul 26, 2010 4:24 pm
Interface: TC Impakt Twin
FW Controller: SIIG; http://www.bhphotovideo.com/c/product/629062-REG/SIIG_NN_E38012_S3_FireWire_800_PCI_Express_x1.html
Chipset:TI XIO2213
Rating: EXCELENT!!!
Never had anything better in my life or any better configuration.
Working on 128 BS, no clicks, no dropouts, freezes or anything at all.
Basari Studios
Cubase 8.5 Pro. Windows 7 X64. ASUS SaberTooth X99. Intel I7 5820K. ASUS GTX 960 Strix OC 2GB.
4x8 GB G.SKILL. 2 850 PRO 256GB SSDs. 1 850 EVO 1TB SSD.
Postby GooGoo » Wed Aug 04, 2010 6:16 pm
If I get a TI chipset card do I need drivers for Windows 7 64 bit or does Windows 7 sort all that out itself?? Thanks.
GooGoo
Postby tommygear » Sun Aug 15, 2010 4:04 pm
1. FireWire Audio Device: TASCAM FW1884 (V183)
2. Adaptor Make & Model: Belkin Firewire 3 Port PCI Card (F5U503 Rev.S-3)
3. Card Format & Ports: PCI, 3 External Ports
4. Adaptor Controller: TI Chipset(1394 OHCI Compliant Host Controller)
5. Rating: Very Good
tommygear
Postby Dee » Mon Sep 20, 2010 3:42 pm
Hi guys,
My head is spinning due to trying to get a compatible PCI firewire card and audio unit. I have a windows 7 64 bit system and I am looking for something that will be relatively hassle free with regards to drivers......
Dee
Phoenix web design
Postby Powel » Fri Sep 24, 2010 11:06 am
NO SPAM PLEASE!
Powel
Postby sami12 » Fri Sep 24, 2010 6:19 pm
I have an M-Audio FS410 bus powered and it connects to the PC by way of a cheapo USB/Firewire PCI card. DOn't know what the chipset is but the properties say VIA OHCI. My motherboard is an Intel - quite an old P4 board, but it keeps going!
<a href="http://www.downloadvlcplayer.net">vlc player download</a>
sami12
Postby Karmakoza » Thu Mar 10, 2011 10:46 am
1. FireWire Audio Device: MOTU Traveler
2. Adaptor Make & Model: LaCie FireWire 400 PCI Card
3. Card Format & Ports: PCI, 3x 400 external
4. Adaptor Controller: Texas instruments Chipset
5. Rating:
Excellent (achieves low latency with no clicks or pops)
I also have a Focusrite Liquid Mix 32 connected to my PC mobo's f/w port. This is also a Texas instruments Chipset. In my case, I used to get severe dropouts, crackles, Liquid Mix problems & system crashes. After a lot of frustration and experimentation I figured it out that the 2 firewire devices, although separate devices, were sharing the same bus! Looking at the schematic of my mobo in the manual, I was able to put the Lacie card in another PCI slot. Problem solved. I can now use both without problems.
BTW: I have a Gigabyte GA-P55A-UD4 mobo with intel i5 CPU running W7 32bit and Cubase 5
Karmakoza
Postby Dee » Sun Apr 03, 2011 10:40 pm
Hi,
I am hoping I can get pointed in the right direction for a new soundcard. I think firewire will be best for me and have a budget of around £300 - preferably less considering my outlay over the past few months - put it this way, divorce proceedings could get underway soon :headbang:
I have a i7 running windows 7 64bit with 12gb ram - I currently am using a 0404 but bought a node nt2a and would like to go hook up.
My requirements would be this:
Connect the nt2a directly to soundcard via xlr
connect keyboard via 1/4 jack stereo
midi in and out
that's it......if there were a few extra connections then I'll not complain but that is my basic setup.
Any recommendations?
My motherboard is a Asus P6X58D-E intel X58 (socket 1366) - the spec says it has two firewire ports but I have no idea if these have the TI chipset.........basically, I don't really know what I'm talking about!! Therefore any advice, hints and/or tips would be greatly appreciated.
Dee
Postby RonnieG » Thu Apr 07, 2011 10:27 pm
Karmakoza wrote:1. FireWire Audio Device: MOTU Traveler
5. Rating:
Hmmm.
i have 3 PCI slots . 3 is empty 1&2 have firewire cards in. Liquid Mix in No 2 Presonus Firestudio mobile in No1 ) (no onboard firewire). Are you saying that there may be a possibility that the Pci slots in some combination or another (slot 1&2.. or 1&3 etc etc) could be using the same Buss? Hence me having real issues with a Liquid mix (on slot 2) continually dropping out.
Could it be worth (silly question!) me changing the slot combinations? (1& 3 ?)
RonnieG
Postby Martin Walker » Fri Apr 08, 2011 12:41 pm
Hi Ronnie!
Have a read of this of this rather arcane PC Musician feature of mine entitled ‘The Musician's Guide To PCI Slots & Interrupts’:
www.soundonsound.com/SOS/may03/articles ... an0503.asp
It will explain the intricacies of the Interrupt Request Table, which may be just what you need to know, as it determines how the various slots and other PCI devices share their interrupt resources ;)
Postby RonnieG » Fri Apr 08, 2011 6:05 pm
Thanks Martin
I've started a new thread for my questions to avoid thread hijack.... :blush:
RonnieG
