Your Recommended FireWire Adaptor Cards
Re: Your Recommended FireWire Adaptor Cards
Postby GooGoo » Wed Aug 04, 2010 6:16 pm
If I get a TI chipset card do I need drivers for Windows 7 64 bit or does Windows 7 sort all that out itself?? Thanks.
GooGoo
Postby tommygear » Sun Aug 15, 2010 4:04 pm
1. FireWire Audio Device: TASCAM FW1884 (V183)
2. Adaptor Make & Model: Belkin Firewire 3 Port PCI Card (F5U503 Rev.S-3)
3. Card Format & Ports: PCI, 3 External Ports
4. Adaptor Controller: TI Chipset(1394 OHCI Compliant Host Controller)
5. Rating: Very Good
tommygear
Postby Dee » Mon Sep 20, 2010 3:42 pm
Hi guys,
My head is spinning due to trying to get a compatible PCI firewire card and audio unit. I have a windows 7 64 bit system and I am looking for something that will be relatively hassle free with regards to drivers......
Dee
Postby sami12 » Fri Sep 24, 2010 6:19 pm
I have an M-Audio FS410 bus powered and it connects to the PC by way of a cheapo USB/Firewire PCI card. DOn't know what the chipset is but the properties say VIA OHCI. My motherboard is an Intel - quite an old P4 board, but it keeps going!
<a href="http://www.downloadvlcplayer.net">vlc player download</a>
sami12
Postby Karmakoza » Thu Mar 10, 2011 10:46 am
1. FireWire Audio Device: MOTU Traveler
2. Adaptor Make & Model: LaCie FireWire 400 PCI Card
3. Card Format & Ports: PCI, 3x 400 external
4. Adaptor Controller: Texas instruments Chipset
5. Rating:
Excellent (achieves low latency with no clicks or pops)
I also have a Focusrite Liquid Mix 32 connected to my PC mobo's f/w port. This is also a Texas instruments Chipset. In my case, I used to get severe dropouts, crackles, Liquid Mix problems & system crashes. After a lot of frustration and experimentation I figured it out that the 2 firewire devices, although separate devices, were sharing the same bus! Looking at the schematic of my mobo in the manual, I was able to put the Lacie card in another PCI slot. Problem solved. I can now use both without problems.
BTW: I have a Gigabyte GA-P55A-UD4 mobo with intel i5 CPU running W7 32bit and Cubase 5
Karmakoza
Postby Dee » Sun Apr 03, 2011 10:40 pm
Hi,
I am hoping I can get pointed in the right direction for a new soundcard. I think firewire will be best for me and have a budget of around £300 - preferably less considering my outlay over the past few months - put it this way, divorce proceedings could get underway soon :headbang:
I have a i7 running windows 7 64bit with 12gb ram - I currently am using a 0404 but bought a node nt2a and would like to go hook up.
My requirements would be this:
Connect the nt2a directly to soundcard via xlr
connect keyboard via 1/4 jack stereo
midi in and out
that's it......if there were a few extra connections then I'll not complain but that is my basic setup.
Any recommendations?
My motherboard is a Asus P6X58D-E intel X58 (socket 1366) - the spec says it has two firewire ports but I have no idea if these have the TI chipset.........basically, I don't really know what I'm talking about!! Therefore any advice, hints and/or tips would be greatly appreciated.
Dee
Postby RonnieG » Thu Apr 07, 2011 10:27 pm
Karmakoza wrote:1. FireWire Audio Device: MOTU Traveler
5. Rating:
Hmmm.
i have 3 PCI slots . 3 is empty 1&2 have firewire cards in. Liquid Mix in No 2 Presonus Firestudio mobile in No1 ) (no onboard firewire). Are you saying that there may be a possibility that the Pci slots in some combination or another (slot 1&2.. or 1&3 etc etc) could be using the same Buss? Hence me having real issues with a Liquid mix (on slot 2) continually dropping out.
Could it be worth (silly question!) me changing the slot combinations? (1& 3 ?)
RonnieG
Postby Martin Walker » Fri Apr 08, 2011 12:41 pm
Hi Ronnie!
Have a read of this of this rather arcane PC Musician feature of mine entitled ‘The Musician's Guide To PCI Slots & Interrupts’:
www.soundonsound.com/SOS/may03/articles ... an0503.asp
It will explain the intricacies of the Interrupt Request Table, which may be just what you need to know, as it determines how the various slots and other PCI devices share their interrupt resources ;)
Postby RonnieG » Fri Apr 08, 2011 6:05 pm
Thanks Martin
I've started a new thread for my questions to avoid thread hijack.... :blush:
RonnieG
Postby BenoMill » Mon Jun 06, 2011 3:21 pm
thanks for the info, appriciate it.
BenoMill
Postby Metheny » Wed Nov 06, 2013 6:50 pm
Dear all,
I have read the posts in this thread, please let me tell you about a problem I'm experiencing with this hardware:
Audio interface: Echo Audiofire 4
Laptop: Dell 1558, with built-in Ricoh firewire port and a Express Card expansion slot.
This Dell 1558 laptop has a Ricoh chipset, bad for audio production. The audio stops while using the ASIO driver.
I have purchased a Startech express card:
http://www.startech.com/Cards-Adapters/FireWire/2-Port-ExpressCard-IEEE-1394-Firewire-Card~EC13942
But unfortunately, this card does not work with this laptop. Windows does not start because of a resource conflict. And trying to plug the card after Windows startup did not work too, the system does not detect the card and does not install the IEEE Texas Instruments driver.
I'm thinking of buying a second Express card (the following), but I'm afraid it won´t work. I have contacted the manufacturers, but they do not provide any information about compatibility.
http://www.delock.de/produkte/F_259_FireWire_61387/merkmale.html
Any ideas or feedback is appreciated.
Regards,
Metheny
Postby Guest » Fri Nov 29, 2013 8:53 am
Due to the wide range of FireWire (IEEE 1394) chipsets and cards available today it is not possible for us to test every possible configuration. In many situations users will not experience any problems using their Focusrite product with their current setup.
Guest
Postby midierror » Fri Jan 01, 2016 11:46 am
Thanks for the heads up! I have been given a liquid mix and have just ordered the recommended card.
Cheers
midierror
Postby Dramatic Hammer » Sun Mar 06, 2016 10:08 pm
The last post here is pretty old but does anyone have any idea how I can get my firewire card working in windows 7? It's a new skylake/z170 build and I'm getting a code 10 error with a Dynamode PCI-3PFW card (VIA chip).
I've tried choosing legacy drivers in device manager, to no avail :frown:
Dramatic Hammer
Postby Exalted Wombat » Mon Mar 07, 2016 12:11 am
There have been reports of Firewire problems with these new motherboards. Sometimes grabbing the latest BIOS has helped.
If it's new build, why is it Windows 7? With brand new hardware, at least give Microsoft a CHANCE to keep up-to-date alongside you!
Exalted Wombat
