Steinberg eLicenser
Steinberg eLicenser
Postby OneWorld » Mon Mar 28, 2011 2:29 pm
I have Cubase SX4, Hypersonic, and Tascam GVI and use a Syncrosoft key for the licenses. I am thinking of buying Halion Sonic and the advert says 'Requires Steinberg eLicenser USB Key' does that mean I need an additional USB key or can my existing one be used?
OneWorld
Re: Steinberg eLicenser
Postby Reiknir » Tue Mar 29, 2011 1:53 am
Yes you can, they are the same thing, Steinberg bought the technology from Synchrosoft but not the name and thus had to rename the thing an e-licenser
Reiknir
Postby OneWorld » Wed Mar 30, 2011 12:54 pm
Thanks, I contacted the retailer as well and they assure me the existing key will work
OneWorld
Postby Exalted Wombat » Wed Mar 30, 2011 1:16 pm
Though the old key will work, aparrantly there's a new version that uses faster memory or whatever. There's a suggestion it may improve timing in Cubase.
Exalted Wombat
Postby InactiveX » Fri Apr 01, 2011 7:23 am
Do you have any sources for that, EW?
Hadn't heard that before, and I'm interested.
InactiveX
Postby Exalted Wombat » Fri Apr 01, 2011 11:09 am
Probably the forum at www.steinberg.net
Exalted Wombat
Postby tex » Fri Apr 01, 2011 4:35 pm
Exalted Wombat wrote:Though the old key will work, aparrantly there's a new version that uses faster memory or whatever. There's a suggestion it may improve timing in Cubase.
Fraid that was a myth from the original dongle "brick" about ten years ago. Got both. No difference.
Timing issues are due to system clocks which the dongle has not got.
tex
Success is round the corner. It's also round the bend.
Postby Dynamic Mike » Sun Apr 03, 2011 2:08 am
E-licenser doesn't appear to have improved my timing issues in Cubase. The first line of the vocals still appears to come in slightly late and the guitars invariably speed up towards the end of each take. :D
Dynamic Mike
Innovation usually starts with someone thinking out loud.
Postby Exalted Wombat » Sun Apr 03, 2011 5:54 pm
This from Steinberg's support site:
https://www.steinberg.net/en/support/knowledgebase_new/free_articles/kb_show/usb-elicensersteinberg-key-details-tips-and-troubleshooting/kb_back/2020.html
But please yourself what you believe :-)
I have heard that different hardware revisions of the USB-eLicenser exist. What are the differences and is there an impact on applications using this USB-eLicenser?
Products which have been released between April 2002 and mid 2003 have been delivered with a USB-eLicenser of 6.5 cm (2.6 inches) in length. A new hardware revision has been included since then and these newer USB-eLicensers are a bit shorter and have a length of ~5 cm (2 inches). The new, shorter USB-eLicensers are using a faster processor. When working with complex Cubase or Nuendo projects, the hardware revision of the USB-eLicensers can have an effect on the responsiveness of the application in certain areas. So if you are using an older, longer key it might be useful to replace it with a newer, shorter USB-eLicenser. In this case please contact your dealer or national distributor to purchase a new, empty USB-eLicenser to transfer the license(s) to.
Exalted Wombat
Postby ken long » Sun Apr 03, 2011 6:32 pm
Wow. Pretty good marketing talk. Translation: buy a new key.
ken long
I'm All Ears.
Postby Exalted Wombat » Sun Apr 03, 2011 6:45 pm
It retails around £15. Not their most rapacious upgrade :-)
Exalted Wombat
Postby debee » Sun Apr 03, 2011 9:54 pm
Dynamic Mike wrote:E-licenser doesn't appear to have improved my timing issues in Cubase. The first line of the vocals still appears to come in slightly late and the guitars invariably speed up towards the end of each take. :D
Had this problem as well - fixed it by changing the FW driver to the legacy FW driver (manually, in driver update). Worth trying if still bugs you ;]
debee
