problem with plugins
Postby semajjames » Sat Apr 02, 2011 9:12 pm
hi
my O/S is win 7 64 bit and i have cubase 4 and a whole load of what i assume are 32 bit plugins
what i have done is installed cubase 4 as 32 bit expecting all my plugins to work as cubase is 32 bit
what i am finding is they do not work
so when running a 64 bit O/S do the plugins have to be 64 bit or are 32 bit plugins ment to work if 32 bit cubase is installed on a 64 bit O/S
cheers
semajjames
Re: problem with plugins
Postby The Elf » Sat Apr 02, 2011 10:05 pm
Most 32-bit plug-ins will work fine under Win7 64-bit. But Cubase 4 is a bit old - that may be the real source of your problems.
Postby semajjames » Sun Apr 03, 2011 11:51 am
mmmm thanks i never thought about it like that
so 32 bit plugins should work fine on 64 bit O/S with 32 bit cubase
whilst we on about updates ,,,, does there come a point where one can no longer update cubase and one HAS to buy a full copy
or do they every now and again bring out a new version that one cannot update to ??
semajjames
Postby Billum » Sun Apr 03, 2011 12:01 pm
Yes 32bit plugins work fine in a 64bit OS as long as the host (Cubase in this case) can handle them - and 32bit Cubase can normally handle them all! 64bit Cubase 6 is getting there too... (and third-party jBridge tends to mop up the rest!).
Yes, at the moment you can only update from Cubase 4 & 5 to Cubase 6 - the next version (which won't be out this year, I'm sure) will presumably only update from v5 & 6, so perhaps you should jump before too long (and go 64bit while you're at it! It's great.)
Steinberg have just released the last update to Cubase 5 too, so only v6 will have any fixes from now on.
Billum
