I'm having a bit of a problem with Cubase 5. When trying to change a the sample rate Cuabse keeps through up a dialogue box that says 'Could not create audio directory!' and then doesn't actually change the sample rate even though it says it has in the the project info at the bottom of the screen. It then says that a serious error has occured and Cubase needs to be restarted after you've saved your work. It then says that it can't save over the existing project and calls it 'project-01' instead. I've checked my paths and made sure that there is enough space on the drive I'm saving to but it stills trows up this error. Any ideas?
Cubase 5: Could not create audio directory!
• Page 1 of 1
The Splatt - Poster
Crush your enemies, see them driven before you, and hear the lamentation of their women.
Re: Cubase 5: Could not create audio directory!
What does it say in the eLCC?
- tex
- Regular
Success is round the corner. It's also round the bend.
Not sure. I'll check and get back to you.
The Splatt - Poster
