Nuendo 3-pan automation gone crazy
Postby zaphin » Fri Apr 08, 2011 12:30 pm
Hi there,
My pan automation on one of my tracks has gone crazy. I can set it to extreme Left ok - goes up to "99" and then "L". But at one point the automation has gone off the channel display and says that it is "R21567".
I can't see the points where this supposed "R21567" is, so can't click on them to move them back into the 1-99 range. So at that point in the track I can't actually alter the pan on that track...
Has anyone encountered this before? Is there a fix?
Many thanks for any help!
zaphin
Re: Nuendo 3-pan automation gone crazy
Postby zaphin » Fri Apr 08, 2011 12:33 pm
Ah - I put a mono sample on a stereo channel - could it be to do with this?
zaphin
Postby zaphin » Mon Apr 11, 2011 4:47 pm
Anyone have a solution??
It's happening a fair bit and means I can't do any more automation on that channel... Quite a big problem..
Cheers,
zaphin
Postby The Elf » Mon Apr 11, 2011 5:10 pm
Can you create a new track and re-import the audio file into it? That should get you up and running.
Postby zaphin » Mon Apr 11, 2011 7:17 pm
Hey, thanks for the suggestion. They're pretty huge tracks with lots of imports on them so it's a bit difficult... I have found that I can copy and paste other automation over the problem areas - it doesn't fix the whole channels issues but it lets me re-do the problem areas at least...
It's really weird, never happened before, hopefully it's just an issue in this project - never to return!
zaphin
