EZDrummer/32bit Win7
Postby KevetS » Sat Apr 23, 2011 4:30 pm
I'm interested in buying EZDrummer.
But, apparently it's only (officially) compatible with XP
Anyone tried it with Win7 32bit?
If no go, then any alternative suggestions appreciated.
KevetS
Re: EZDrummer/32bit Win7
Postby scw » Sun Apr 24, 2011 9:04 am
I use it with windows 7. The os is installed as 64 bit but Cubase and my plugging (including) ezdrummer are 32 bit. Never had any issues with it.
Stewart
scw
Postby Remeniz » Sun Apr 24, 2011 9:22 am
I have it installed on my Windows 7 64 bit rig and it runs fine.
The oldest piece of software I have is Cool Edit Pro, yes I still it, and that runs fine on Windows 7 64.
Remeniz
Postby KevetS » Sun Apr 24, 2011 11:03 am
Thanks guys.
I guess if it runs on Win 7 64bit, then Win 7 32bit should be ok.
I'll be taking the plunge then 8-)
KevetS
Postby il Padrino » Sun Apr 24, 2011 11:57 am
The x86 and version works perfectly under Windows 7 x86 and Windows x64. Remember that there is also an x64 version of the plugin for 64 bit hosts, which also works perfectly.
il Padrino
Postby Glyn Barnes » Mon Apr 25, 2011 9:15 am
If you are using a 64 bit host its important to go to your Toontrack account (once you have regestered your software) and download the latest version. Toontrack does not support 32/64 bit bridging software.
In Sonar 8.5 64 bit for example the 32 bit version will start, but it won't load samples.
The latest version installs and updated 32 bit version and a 64 bit version.
Glyn Barnes
