Windows 10 for musicians SOS article
Re: Windows 10 for musicians SOS article
Postby OneWorld » Sun Jan 10, 2016 1:24 pm
The Elf wrote:
alexis wrote:
ef37a wrote:
ezza wrote:
ef37a wrote:The Post Ghost has struck again!
I was sure I asked if the factory recovery partition on my HP laptop would allow a return to W7 at any time if I went ahead and installed the free W10?
The Windows 10 installer will back up your Win 7 install and revert back to it (with all your settings and programs intact) whether you have a recovery partition or not.
Really? Not the impressive I have got. So, I have ABSOLUTLY NOTHING TO FEAR INSTALLING W10 ON THIS LAPPY?
Image first!
+99!
If there were ever 2 words that have profound impact on life, it is those 2 words 'Image First' Yes of course there are a few other 2 word phrases equally profound but computing wise 'IF' is surely the most important
OneWorld
Postby alexis » Sat Feb 06, 2016 6:53 am
Having upgraded to W10 (I IF'd!!), and played around with the settings a bit, I just have one question. The computer is 97% DAW, 3% general surfing machine btw. I'm wondering whether I should check the box "Defer Updates".
Seems like a reasonable thing to do - helps the user bypasses the inevitable dodgy upgrades while MS works on a hot fixes to rectify (thereby avoiding potential DAW downtime), while still getting security updates as they are released.
Thanks for any thoughts!
alexis
Cubase 9.0.1; i5-4570 3.2GHz,16GB RAM;W10 64bit on Samsung SSD840 Pro256GB;Seagte 1TB SATA600 Audio;UR28M;Motif8;UAD2Solo;Jamstix 3.3;BCF2K;TC Helicon VoiceOne;RevoicePro3.2
Postby robinv » Sat Feb 06, 2016 2:40 pm
Personally, i've been finding that with each update my computer gets "better", but accepted wisdom says you should defer.
robinv
Molten Music Technology - Computers for doing music on
Making Music on the Microsoft Surface
Postby alexis » Sat Feb 06, 2016 6:15 pm
robinv wrote:Personally, i've been finding that with each update my computer gets "better", but accepted wisdom says you should defer.
Thanks for that, robinv!
I should also explicitly thank you for your great article. So glad it is pinned to the top of this subforum! I reviewed it last night as I was setting up my new W10 - great resource.
One other question for your or any other W10 cognoscenti - regarding MalwareBytes.
The W10 update process was done on my DAW, by ADK remotely. I noticed before they upgraded they seemed to remove MalwareBytes from my computer, "the upgrade works better with it gone" they answered when I asked.
So, after all was said and done, there was no trace of MalwareBytes on my computer. I contacted them, and within hours they had emailed me my personal code (worth $$), and now I'm up and running with that as well.
But ... I will be doing the upgrade on my other computers myself ... and am wondering - do I really have to wipe all traces of MalwareBytes from my computers before doing so?
alexis
Postby JSantos » Thu Mar 03, 2016 1:57 pm
Just recently updated to Windows 10 earlier this morning.
Then I had to roll back because
-plenty of my drivers were missing. My ASIO was even mis-aligned. :frown:
-my wifi adapter wasn't working. also my LAN card.
-some USBs lost functionality.
I upgraded from Windows 7 Ultimate Edition to Windows 10. I believe registry troubles caused these little problems.
Has anyone ever encountered a different outcome coming from Windows 7 Ultimate? I'm planning to do a fresh install instead of proceeding with an upgrade.
JSantos
Postby damoore » Thu Mar 03, 2016 4:08 pm
You were lucky. When I tried to update to W10, my machine wouldn't even boot. Had to completely reinstall 7.
The software I had used to clone my disk before hand did not create a bootable drive, too, so it was back to square 1. At least I was able to get all my files back.
damoore
Postby alexis » Fri Mar 04, 2016 5:33 am
damoore wrote:You were lucky. When I tried to update to W10, my machine wouldn't even boot. Had to completely reinstall 7.
Hi - I don't know much about these things ... so I was under the impression that a clone was a bit-for-bit copy from one drive to another, so it would be supposed to create that bootable drive.
Where is that thinking in error, yikes!?
alexis
Postby Bojet » Sat Oct 08, 2016 3:54 pm
Hi all,
I'm on Windows 10 with Pro Tools 12 HD. My problem is when I try to import a video to PT (no matter what kind of... mp4, mov, avi, whatever) it can't import it. I installed the latest quicktime (7.7.9) and Avid codecs LE 2.7.3 for win...
But no luck.
Any help?
Thanks a lot!
Bojet
Postby robinv » Mon Oct 10, 2016 9:10 pm
Bojet wrote:Hi all,
But no luck.
Any help?
Thanks a lot!
Hi Bojet - welcome to the forum!
Do these videos play back ok generally in Windows in Films/TV or Media Player?
robinv
Postby fxsoundscapes » Mon Nov 26, 2018 3:52 pm
I found that WIN 7 was much more problem free in so many ways. After switching to win 10 all the problems started with daw software, plugins etc. :headbang:
So it needs some figuring out and setting changes but once you get there it works just fine. :thumbup:
fxsoundscapes
Postby N i g e l » Fri Aug 09, 2019 10:47 am
Dont be afraid to ask the hyper global mega Microsoft corporation support team for help.
When I first read Robins article intro I was highly sceptical that Microsoft were keen to help *me* get the best Windows 10 experience.
This week I contacted Microsoft support for the 1st time using the chat app (about my THR10 editor problem). I now stand corrected and am impressed by their level of commitment .
Amazing ! There was no waiting & after 3 guesses the AI robot gave up and put me through to a real person. He knew his stuff and was very keen to help. Unable to solve the problem at his level, he connected me to the Level 2 support. Again very efficient and keen to assist me achieve a solution to the problem.
This was all over a couple of hours of Microsofts time.
Postby shmuelyosef » Sun Oct 13, 2019 8:52 pm
I have always been windows and Unix (never MAC or iOS), and have lived with the 'wonkiness' of it all. I am delighted with Windows since moving to Windows 10 PRO. I have also let the updates run unfettered in both my laptop (recent) and DAW Workstation (7-8 year old custom tower build).
Thanx for the pointer to this (albeit dated) article!
shmuelyosef
Postby adrian_k » Thu Apr 02, 2020 6:57 pm
A bit of a post script - I finally upgraded my 6 year old W7 laptop today. Wouldn’t have bothered but my DAW is no longer supported on W7. Bit of a faff, a couple of hangs, a reboot and 2 attempts but got there in the end.
If there is anyone else out there on W7 and thinking of upgrading note that despite what MS have said you can still upgrade for free. I followed the instructions here:
ZDNET article
adrian_k
getting better all the time..
