SoundCard interference noise
Re: SoundCard interference noise
Postby Martin Walker » Thu Sep 01, 2005 3:49 pm
It's not cleaning up the PSU, but breaking the ground loop that gets rid of these background noises.
Postby Martin Walker » Thu Sep 01, 2005 3:56 pm
James - if your powered monitors have balanced inputs then a balanced cable will do the trick for you.
Postby James Covell » Thu Sep 01, 2005 8:03 pm
Hi everyone,
Well... I tried the balanced cables - unfortunately they didn't solve the problem. In fact they were worse for picking up general noise. So as a last resort I disconnected the earth from the laptop power supply. Perfect - no interference or noise what so ever. As for safety issues (see ground loops thread)... I'm not convinced that it's such a major problem. I know someone with a Samsung laptop (only a year old) and it's power supply isn't earthed at all. Take radio/cassette players, they have a standard two pin 'figure of eight' connection - that's mains power straight into the unit.
Luis and everyone else with this problem - just get rid of the earth on your power supply. Then you can get on with the important stuff like making music!
James
-Big thanks to everyone for their input.
James Covell
Postby jammer » Fri Sep 02, 2005 12:16 am
James Covell wrote:Luis and everyone else with this problem - just get rid of the earth on your power supply. Then you can get on with the important stuff like making music!
James
just remember ... your risking killing yourself or others.
jammer
jammer <a href="http://www.product23.co.uk/">Product23.co.uk</a>
Postby Martin Walker » Fri Sep 02, 2005 3:12 pm
The big difference between those laptops with a figure of eight mains cable and the ones that are earthed tends to be metalwork on the case i.e. plastic cases generally have 2-wire mains cables, largely metal ones have 3-wire mains cables. if you remove the earth this will be floating, and in a fault condition could become live and be extremely dangerous.
On your own head (or heart) be it :shock:
Postby James Covell » Sat Sep 03, 2005 4:56 pm
Hi Martin,
My laptop case is entirely plastic, and the power supply is a generic unit manufactured by a third party company. On the other hand my portable hard drive has a solid metal case. The power supply for this uses a 2 pin figure of 8 plug! - this MUST be breaching safety regulations.
James.
James Covell
Postby James Covell » Sat Sep 03, 2005 5:01 pm
I was wrong to advise anyone else to do what I've done and I take that back. Do what you know is safe.
James Covell
Postby Martin Walker » Mon Sep 05, 2005 12:18 pm
James Covell wrote:Hi Martin,
James.
Not if it's double insulated - many hi-fi amps, CD players, and so on have both metal cases and 2-wire mains leads with no issues.
