LINK 79: 2007 PC NOTES COLUMNS
Postby Martin Walker » Fri Jul 04, 2008 2:02 am
JAN 2007: www.soundonsound.com/SOS/jan07/articles ... s_0107.htm
DirectX Plug-ins & Cubase 4 - support dropped
DX-only Plug-ins
Getting Wrapped Up - freeware wrappers that allow DX plug-ins to be used in Cubase 4
DX Project Management - converting DX-using Cubase SE/SL/SX projects to Cubase 4
Notebook Battery Overheating ALert
FEB 2007: www.soundonsound.com/SOS/feb07/articles ... s_0207.htm
Windows Vista - should you upgrade or wait?
Increased Security, Aero Graphics, Main Features, available versions
Passing The Driver Test - digital signing of 64-bit Vista drivers.
Plug-in Spotlight - KV331 Audio's Synth Master
MAR 2007: www.soundonsound.com/SOS/mar07/articles ... s_0307.htm
Available 64-bit Vista drivers
Digital Rights Management worries
Putting The Boot In - Boot Managers compared
Tiny Tips - how to check whether elderly applications are using dual-core processors to the full
APR 2007: www.soundonsound.com/SOS/apr07/articles ... s_0407.htm
Drive Tricks - how to transferring data from a hard drive from an old PC to a new one
Preset Preservation - finding and transferring your application and plug-in preset data
Box Clever - organising challenge/response protection
Vista News & Performance
Conroe Dual-core Performance Test Results
Tiny Tips - Firewalls & Low-level utility problems
MAY 2007: www.soundonsound.com/SOS/may07/articles ... s_0507.htm
The Slot Machine Gamble - PCI version problems on modern motherboards
5-volt and 3.3-volt signalling and elderly soundcard issues
Acustica Audio Nebula 2 Free review
JUN 2007: www.soundonsound.com/SOS/jun07/articles ... s_0607.htm
Cubase 4 Preset Management - FXP/FXB limitations
Converting existing preset libraries to Cubase 4 format
Spyware Doctor 5.0 review
Shareware Spotlight - Golden ASET
JUL 2007: www.soundonsound.com/SOS/jul07/articles ... s_0707.htm
AMD-Intel Price War
HarBal 2.3 Review
Shareware Spotlight - Reaper Updates
AUG 2007: www.soundonsound.com/SOS/aug07/articles ... s_0807.htm
Speeding Up The Windows XP Booting Process
Autoruns Utility
Pre-Fetch Myths
Windows XP Shutdown Times - Registry tweaks
SEP 2007: www.soundonsound.com/SOS/sep07/articles ... s_0907.htm
On-line CPU Speed Converter utility
Cubase, Nuendo & Vista Performance
L-Factor II Benchmark Test
Sonar & Vista - WDM/KS driver improvements after installing Windows update
OCT 2007: www.soundonsound.com/SOS/oct07/articles ... s_1007.htm
Virus Checking- freeware virus checkers compared
On-Demand Virus Checking - how to disable background checking when running audio applications
Virus Double Checking - checking suspicious files on-line
Tiny Tips - Remove Hotfix Backups utility
Shareware Spotlilght - NuSofting's Harptime Pro
NOV 2007: www.soundonsound.com/SOS/nov07/articles ... s_1107.htm
Steinberg VST ID's Explained
Missing Plug-Ins - multiple plug-ins with the same ID
Obscure ID Issues - VST ID changes between software versions
The Developer's Dilemma - multiple versions on same machine, or one ID suits all?
ID Hacking - how to change a VST ID to make plug-ins reappear
Tiny Tip - automatic clock problems with multiple booting PCs
DEC 2007: www.soundonsound.com/SOS/dec07/articles ... s_1207.htm
Bit Transparency - Kernel Mixer Problems
Bypassing the KMixer
Digital Decisions - how to avoid DSP changes and achieve bit transparency
Clear & Simple - how to check if your audio is bit-transparent
RightMark Audio Analyser 6 review
