Best Format for USB Stick, for swapping Windows and Mac?
Page 1 of 1
Re: Best Format for USB Stick, for swapping Windows and Mac?
PostPosted: Tue Jul 30, 2019 8:48 am
by Kathi F Elder
If you expect to transfer files between a Windows computer and a Mac, you should decide on either FAT32 or exFAT.
Step 1: Plug the flash drive into the USB port.
Step 2: Launch a Finder window.
Step 3: Run Disk Utility.
Step 4. Choose a format for your flash drive.
Step 5. Format your flash drive.
Every time you want to permanently delete files on your USB drive, you don’t have to format it again. You can just use a reliable file shredder to conveniently erase files in a secure way.
iMac-Cleaner File Shredder does just that. You can use it to delete confidential files on your Mac, external hard drives, and SD cards as well.
PostPosted: Fri Aug 02, 2019 7:29 am
by FrankRaz
Personally I wouldn't use a big drive with exFAT. I used to have a 3TB exFAT formatted drive that I used to use between Mac and PC. It was all fine when I was alternating between the two regularly but if I used it for a long period on PC only, the next time I used it with Mac it would take ages to mount. One day it wouldn't mount. I tried it with a PC and it was fine so I plugged it into the Mac again and left it. There was nothing wrong with it, it just took an hour to mount. Nowadays I use a couple of 500GB drives and use them as go betweens only, trying not to keep anything on them permanently and I've not had a problem since.
