Interface Mbox com dirves asio usb no XP?
Postby Vobiscum » Thu Mar 08, 2018 12:45 am
Boa noite
Tenho um interface de de audio Mbox e com as drives usb asio e quero a usar os inputs e output no cubase e nao estou a conseguir porque durante a gravação cria uma grande chiadeira em quanto gravo.
O interface nao tem qual quer problema pk já experimentei noutro pc mas quero usar no XP de bancada e nao estou a conseguir gravar sem ter que usar as drives asio4all.
Alguem me consegue dizer como posso resolver o problema pk pretendo mesmo usar o XP como sistema operativo?!
Vobiscum
Re: Interface Mbox com dirves asio usb no XP?
Postby zenguitar » Thu Mar 08, 2018 1:17 am
And here is a translation from the original Portugese courtesy of Google translate...
good evening
I have a Mbox audio interface and the asio usb drives and I want to use the inputs and output on the cubase and I'm not getting it because during the recording it creates a big chiadeira in how much I record.
The interface does not have any problem pk I've tried another pc but I want to use it in XP and I'm not able to write without having to use the asio4all drives.
Can someone tell me how I can solve the problem pk I even want to use XP as an operating system ?!
Espero que isso ajude.
Yogi Berra
Postby Vobiscum » Thu Mar 08, 2018 1:32 am
Agradecia que me respondessem só há questão do post e nada mais!!!
Vobiscum
Postby ef37a » Thu Mar 08, 2018 12:14 pm
Blimey!
If the OP is really stuck with XP maybe find an old AI? The M-A Fast track pro was pretty good, well, mic pres are dire compared to todays but generally it handled audio well and latency was low even considering it was a USB 1.1 device.
Might also find a Tascam US 122?
Postby Vobiscum » Fri Mar 09, 2018 12:58 am
Boa noite,continuo sem respostas ao meu problema,uma soluçao digna:não preto alterar sistema operativo ou interface.
Sff ajuda digna e menos palpites.
Vobiscum
