Has anyone succesfully used a 10 metre Firewire cable
Postby tc99 » Wed Apr 18, 2018 1:23 pm
According to the SOS article from some time ago the max recommended length for Firewire cables is 4.5m. I wonder has anyone used a 10 metre cable . . there are a couple on ebay, so maybe it is possible. In the same article it recommended max length of USB to be 5m, and i have used 10 metre, so maybe longer the length is possible with Firewire
tc99
Re: Has anyone succesfully used a 10 metre Firewire cable
Postby Martin Walker » Wed Apr 18, 2018 4:01 pm
Hi tc99!
I suspect that could be my Hardware Safety Guidelines For The PC Musician way back in SOS October 2005:
https://www.soundonsound.com/techniques ... c-musician
Thankfully such information doesn't get outdated - as I said there " the maximum recommended lengths for Firewire digital cables is 4.5 metres" so you can certainly try a longer one.
There are just no guarantees that this will work reliably, although it may be fine in your application - fingers crossed! :beamup:
Postby Jumpeyspyder » Wed Apr 18, 2018 5:26 pm
We used to run a large format printer on a fifteen meter FW cable.
For something more fussy than a printer, you might want to use a fW hub with two 5m cables
Jumpeyspyder
Postby James Perrett » Wed Apr 18, 2018 9:03 pm
Didn't Max used to recommend a 10m cable from Lindy (or am I thinking of something else...)?
Postby Jumpeyspyder » Wed Apr 18, 2018 10:55 pm
James Perrett wrote:Didn't Max used to recommend a 10m cable from Lindy (or am I thinking of something else...)?
I seem to remember that too
Jumpeyspyder
Postby ef37a » Thu Apr 19, 2018 8:24 am
https://www.amazon.co.uk/LINDY-FireWire ... B000I2JVDM
^ But not exactly cheap and I assume you just need one plus another 5mtr passive to get 9.5mtr?
FWIIW I found my KA6 would work fine on two 5mtr USB 2.0 cables with one PC but with only ONE of the two with another PC, things can get sticky at limits.
Postby Martin Walker » Thu Apr 19, 2018 1:40 pm
ef37a wrote:FWIIW I found my KA6 would work fine on two 5mtr USB 2.0 cables with one PC but with only ONE of the two with another PC, things can get sticky at limits.
Exactly Dave - that's what I was alluding to in my above comment about 'no guarantees' ;)
Postby lost track » Thu Apr 19, 2018 5:25 pm
Not a 10m cable, but a this extender works near-flawlessly on my RME fireface 800. I saw near flawlessly as I remember having to reset it a couple of times. But mostly, a peach.
http://www.lindy.co.uk/usb-firewire-c4/firewire-extenders-repeaters-c242/cat5-firewire-extender-up-to-75m-p483
Careful as sometimes running shorter than 10m will make it less reliable. Stick within the guidelines. Cat5e cable is cheap if you ever decide to run it longer
lost track
Postby lost track » Thu Apr 19, 2018 5:27 pm
lost track wrote:Not a 10m cable, but a this extender works near-flawlessly on my RME fireface 800. I saw near flawlessly as I remember having to reset it a couple of times. But mostly, a peach.
Oh, just noticed the price. I must have got a deal... I must have!
lost track
Postby blinddrew » Thu Apr 19, 2018 5:52 pm
:o
I hope you've got that listed separately on your insurance! ;)
Postby OneWorld » Thu Apr 19, 2018 5:55 pm
At that length I think it would more likely to be referred to a candlewire!
OneWorld
Postby tc99 » Fri Apr 20, 2018 12:10 pm
thankyou everyone
yes Martin that was the article i read. i think i'll just have to give it a go, and see what happens. I think that CATS extender is a bit of overkill for what i want
tc99
Postby Studio Support Gnome » Sat May 26, 2018 1:23 am
Lindy used to do 5, 7.5 and 10m variants.... they might still for all i know.... suffice to say i have several, and they still work, a decade after i bought them.
used them in many many installs, never a single problem with them, except when abused by putting heavy furniture edges on them.... and even then, survived better than most....
Postby Uncle Freddie » Sat May 26, 2018 2:50 am
tc99 wrote:According to the SOS article from some time ago the max recommended length for Firewire cables is 4.5m. I wonder has anyone used a 10 metre cable . . there are a couple on ebay, so maybe it is possible. In the same article it recommended max length of USB to be 5m, and i have used 10 metre, so maybe longer the length is possible with Firewire
I have not, but if I needed a 10m Firewire cable, I would not trust an average computer retail cable; instead I would go straight to Granite Digital for one. I've been using their Firewire cables for 20 years and I have maybe 2 dozen of them. They're thick and have ferrite cores on both ends. Looks like they have a 10m (32 foot) length in both Firewire 400 and 800 formats:
http://www.granitedigital.com/firewire1 ... ables.aspx
Uncle Freddie
Users browsing this forum: ef37a
