Adding multiple external effects in Cubase
Postby Will_m » Tue Aug 14, 2018 11:31 pm
Is there a way to add multiple instances of an external effect or instrument in Cubase?
Currently I have my Roland SE-02 set-up as an external instrument but I can only have one track at a time. If I try and add another instrument track the SE-02 option no longer appears in my list of VSTI's.
The same also happens with my external effects sends I can only set them as an insert once and can't use them on any other track until I remove the effect from the previous track.
Will_m
williammorrismusic.com
Re: Adding multiple external effects in Cubase
Postby The Elf » Wed Aug 15, 2018 8:09 am
You can't add a hardware effect more than once - it wouldn't really make any sense if you could.
But you can add your hardware effect as an insert in an FX Track (for send effects), or a Group Track (for insert effects) and send/route as many sources as you like to those Tracks - problem solved.
