Any recommended volume levelling software?
Postby mikehende » Fri Oct 12, 2018 1:13 pm
Hey guys, I am looking around for a volume levelling software which I can use with Media players like Media Monkey. I was going to try this but it's discontinued:
https://www.claessonedwards.com/live-audio/breakaway-dj
Any recommendations please?
mikehende
Re: Any recommended volume levelling software?
Postby Rich Hanson » Fri Oct 12, 2018 1:21 pm
Media Monkey uses and can calculate ReplayGain so you might not need to, and it can also modify the volume of an audio file if you want it to. Might only be in the paid version but I think it's in the free version.
Rich Hanson
Postby mikehende » Fri Oct 12, 2018 1:40 pm
Thanks, using the normalizer option in MM works [or is not as noticeable] to some extent on smaller home equipment but not when running on DJ equipment at high volume which is why I am looking for a dedicated good volume leveller.
mikehende
Postby mikehende » Fri Oct 12, 2018 5:21 pm
I got a link to these from the MM forum if anyone should be interested:
http://forums.winamp.com/showthread.php?t=452815
mikehende
Postby Kristian E. » Sat Oct 20, 2018 2:59 pm
If you want to make music for the tv broadcast business I recomend that you check if you have a R128 metering option in your DAW. That might also help you levelling for MM. I haven't had the time to look into that subject myself yet, but I've heard that it might be a good aproach.
plz. let me know if I'm completely off here! :?
Kristian E.
