Pops and Clicks Gradually Getting Stronger - Can you help?
Page 2 of 2
Re: Pops and Clicks Gradually Getting Stronger - Can you help?
PostPosted: Wed Oct 17, 2018 8:50 pm
by blinddrew
Yep, should be downloadable I think.
Otherwise you'll just have to use the channel monitor button on reaper.
PostPosted: Wed Oct 17, 2018 10:01 pm
by Wonks
I'm not sure the 2i2 has it as it's a pretty basic 2 in/2 out box. I couldn't see it listed in the software bundle. You can hear the microphone inputs without the signal having to pass into Reaper then out again, by using the 'direct monitor' switch on the front of the unit .
PostPosted: Thu Oct 18, 2018 5:57 am
by ef37a
Once you have the drivers sorted out and Reaper optimized I think you can ignore the MixControl software? (I have never bothered with it with my 8i6 but then I hardly ever bother with the 8i6!)
The 2i2 has a Direct Monitoring switch so I would assume the signal will be routed either from inside the AI or back from Reaper?
PostPosted: Thu Oct 18, 2018 10:12 am
by blinddrew
Ah right, missed that. DM is the much easier option, thanks folks.
PostPosted: Thu Oct 18, 2018 1:47 pm
by Piskeh
ef37a wrote:Once you have the drivers sorted out and Reaper optimized I think you can ignore the MixControl software? (I have never bothered with it with my 8i6 but then I hardly ever bother with the 8i6!)
I would love for the audio to be routed back from REAPER, but I might have to settle with DM. I'll just have to figure that part out. This afternoon hopefully I'll try everything you all suggested and get back with some answers.
Thanks for the help!
PostPosted: Thu Oct 18, 2018 2:23 pm
by Wonks
You can have the input audio routed back from Reaper, but there will always be a slight delay due to latency if you enable the monitoring for that channel in Reaper. Add any insert FX on that channel whilst recording and the latency will get worse. Reverb as a send FX is fine as it doesn't add extra latency and any slight delay in the start of reverb won't be noticeable, whilst it can still help you if you are singing. What you don't want is direct monitoring on at the same time as you have the Reaper channel for that input on at the same time, or you'll get noticeable comb filtering on the sound in your headphones.
PostPosted: Thu Oct 18, 2018 3:26 pm
by Piskeh
Wonks wrote:You can have the input audio routed back from Reaper, but there will always be a slight delay due to latency if you enable the monitoring for that channel in Reaper. Add any insert FX on that channel whilst recording and the latency will get worse. Reverb as a send FX is fine as it doesn't add extra latency and any slight delay in the start of reverb won't be noticeable, whilst it can still help you if you are singing. What you don't want is direct monitoring on at the same time as you have the Reaper channel for that input on at the same time, or you'll get noticeable comb filtering on the sound in your headphones.
Gotcha, my main concerns are being able to hear input before I record to make sure stuff works, hear output after I record it to master etc, and being able to hear the metronome and back tracks while I'm recording so I should be good there.
Thanks!
PostPosted: Thu Oct 18, 2018 4:00 pm
by Wonks
Great. :thumbup: Hope it all works out for you and those pops and clicks disappear. If you continue to have trouble, then you may need to look at some of Pete Kaine's suggestions to see if there are any programs that are taking up all the processor time. But the correct ASIO driver and 44.1kHz or 48kHz 24-bit recording should really make things a lot easier for you.
PostPosted: Thu Oct 18, 2018 4:08 pm
by Piskeh
Wonks wrote:Great. :thumbup: Hope it all works out for you and those pops and clicks disappear. If you continue to have trouble, then you may need to look at some of Pete Kaine's suggestions to see if there are any programs that are taking up all the processor time. But the correct ASIO driver and 44.1kHz or 48kHz 24-bit recording should really make things a lot easier for you.
Thanks a ton! I really appreciate all the willingly helpful people y'all got here. :D
PostPosted: Thu Oct 18, 2018 4:49 pm
by ef37a
Hope you are sorted soon. Note, one of the things that is notorious for causing audio problems is any kind of wireless kit. You might need to disable wireless adaptors in Control Panel>Device Manager but before you do any such hacking, set a Restore point.
PostPosted: Thu Oct 18, 2018 7:20 pm
by Piskeh
ef37a wrote:Hope you are sorted soon. Note, one of the things that is notorious for causing audio problems is any kind of wireless kit. You might need to disable wireless adaptors in Control Panel>Device Manager but before you do any such hacking, set a Restore point.
Wow, wireless adapters can cause problems like that? I'll try disabling mine and see if that helps at all.
Thanks!
PostPosted: Fri Oct 19, 2018 9:27 am
by Pete Kaine
As can pretty much any other device in there, if it has an errant driver. The tests I mentioned previously would tell us if this is indeed the case, rather than you spending your time turning stuff on and off blindly.
PostPosted: Mon Oct 22, 2018 1:33 pm
by Piskeh
I'm recording in 44.1khz and that seems to have alleviated the noise I was getting. Thank you all for your help! Also, I am now using the Focusrite plugin, and I did find out how to set it up as an output device as well as an input device. So, that takes care of pretty much all of my problems now!
Happy recording!
Steve
PostPosted: Mon Oct 22, 2018 1:37 pm
by Wonks
Great stuff! :thumbup:
