Coffee Lake refresh and the 9900K/9700K/9600K on the bench
Postby Pete Kaine » Fri Oct 19, 2018 2:22 pm
I've had them on the bench for the last week or two, time to break them down with DAWBench.
http://www.scanproaudio.info/2018/10/19 ... e-refresh/
Pete Kaine
Re: Coffee Lake refresh and the 9900K/9700K/9600K on the bench
Postby Johnsy » Tue Oct 23, 2018 1:58 pm
Hi Pete,
What temps were you seeing with the 9900, and what were you using to cool it?
Johnsy
Postby Pete Kaine » Wed Oct 24, 2018 10:27 am
Scythe Ninja 4 initially and managed 4.7GHz all core on that before it started to tip 80 degrees and I gave up.
The Dark Rock Pro 4 took me to 5GHz and similar max temps, anything over that is going to need a water loop or a jet engine without a doubt.
Pete Kaine
Postby phongthuam » Fri Oct 26, 2018 7:51 am
9900k's perfomance is higher 5-10% than 8700k, but its cost higher 25%. RIP my wallet
phongthuam
Postby robinv » Tue Dec 11, 2018 5:43 pm
Pete Kaine wrote:Scythe Ninja 4 initially and managed 4.7GHz all core on that before it started to tip 80 degrees and I gave up.
If you're not rockin' the high 90's you're not trying hard enough
robinv
Molten Music Technology - Computers for doing music on
Making Music on the Microsoft Surface
Postby Pete Kaine » Wed Dec 12, 2018 10:25 am
robinv wrote:If you're not rockin' the high 90's you're not trying hard enough
The computer industry equalivent of "If you're not redlining, you ain't headlining"?
Pete Kaine
Postby robinv » Thu Dec 13, 2018 2:01 pm
Definitely.
That Dark Rock Pro 4 is a bit of a beast though - and a free screwdriver. :bouncy:
robinv
Postby resistorman » Fri Dec 14, 2018 12:10 am
Thanks, interesting stuff.
resistorman
future26.com
Users browsing this forum: ef37a
