Cubase Tempo Map help
Postby Chromeman » Tue Aug 27, 2019 11:05 am
I'm a bit stuck with Cubase Artist trying to develop a tempo map for an imported single track file. I've got as far as creating hitpoints (the track has a heavy kick so that bit is straighforward) but I don't know how to go about creating a tempo map. In Pro Tools you just add a marker at each transient and the tempo is adjusted accordingly. I'm working with a mate's system so I'm not that familiar with Cubase, hence the question. Is this even possible with Artist or does he need to get Pro?
Chromeman
Re: Cubase Tempo Map help
Postby ore_terra » Tue Aug 27, 2019 1:25 pm
There’s no tempo detection in Artist? There is in Pro.
ore_terra
Postby The Elf » Tue Aug 27, 2019 4:32 pm
This is trivially simple in Cubase Pro, so yes, it may be a limitation of that cut-down version. But TBH I don't know - maybe one for the Cubase forums?
Postby Chromeman » Tue Aug 27, 2019 7:45 pm
OK thanks, I thought that might be the case. I'll download the 30 day Pro trial to sort this track out. Hopefully it will work as the upgrade is £214 which is not insignificant.
Chromeman
