Reason 3 time signature change
Postby DanR » Fri Nov 01, 2019 5:48 pm
Hi
I was given Reason V3 years ago and although I mainly use Cubase, I’m quite liking the
Reason interface.
Main problem is that I’m unable to add automated time changes to compositions without
Rewiring to another sequencer program.
Just wondering in what version Propellerhead introduced this.
Any help appreciated.
DanR
Re: Reason 3 time signature change
Postby John Egan » Fri Nov 01, 2019 6:08 pm
DanR wrote:Hi
Reason interface.
Dan,
Found this article about Reason V4
https://music.tutsplus.com › tutorials › automating-tempo-time-signature-d...
Hope it helps.
Regards, John
John Egan
Postby DanR » Sat Nov 02, 2019 12:17 am
Thanks for the reply.
Had a look at the article. Problem is that Reason V3 doesn’t have the ‘transport track’ that
V4 onwards has.
This is needed for automated time signature changes.
DanR
Postby John Egan » Sat Nov 02, 2019 11:08 am
DanR wrote:Thanks for the reply.
V4 onwards has.
Yes. It looked to me as though that might be the case. Unfortunately, I started to use Reason with V5, so those earlier versions are outside my experience. It looks as though upgrading or switching to something else are your only options.
Regards, John
John Egan
Postby DanR » Sat Nov 02, 2019 2:38 pm
Thanks. Yes, thought so. I’ve got my Cubase Essentials 8 anyway but find Reason more stable and glitch free for soft synth recording.
DanR
Postby John Egan » Sat Nov 02, 2019 3:49 pm
DanR wrote:Thanks. Yes, thought so. I’ve got my Cubase Essentials 8 anyway but find Reason more stable and glitch free for soft synth recording.
I like Reason very much, though my stuff is much more guitar oriented. I presume you are using Cubase for the actual recording, as I didn't think that the early versions of Reason supported recording at all?
I can certainly recommend the latest version 11 of Reason. That does support recording and VST plugins and has a good set of built in instruments.
Regards, John
John Egan
Postby DanR » Sat Nov 02, 2019 6:51 pm
John Egan wrote:I presume you are using Cubase for the actual recording, as I didn't think that the early versions of Reason supported recording at all?
Yes that’s correct. No audio recording on V3.
I do mainly keyboard triggered instrumental music using the soft synths and sample players.
Occasionally use the audio tracks.
I’ve managed to make a few adjustments in Cubase to help eradicate the audio glitches.
Reason 11 Intro version looks good value though and could replace my V3. No mp3 export
which is a shame.
I use this a fair bit in Cubase.
DanR
