Focusrite Scarlett power up problem
Re: Focusrite Scarlett power up problem
Postby DanR » Sat Nov 23, 2019 1:08 pm
I’ve now sent a technical support enquiry to Focusrite so hope to have it resolved soon.
Thanks for the help and replies.
DanR
Postby DanR » Wed Nov 27, 2019 8:53 pm
Have had a helpful reply from Focusrite with detailed suggestions but the Scarlett still won’t power up when starting Windows.
Have even tried disabling the fast startup option which I’ve read about.
I think I’m done with starting/restarting to check if it works :(.
It just means that I have to unplug the 2i2 before starting the laptop and then plugging it in
again when Windows has loaded.
That’s ok but I’ve been considering upgrading to an interface that has an external power supply option, like the new Steinberg UR22c.
As I do mostly keys/VST, the midi I/O would be useful too.
DanR
Postby Pete Kaine » Fri Nov 29, 2019 10:33 am
*edit after removing original post*
Got ahead of myself on that one.
Found a USB power switch, didn't read the small print about lack of data connection.
Pete Kaine
Postby Pete Kaine » Fri Nov 29, 2019 11:35 am
Dammit... timed out before coming back to reedit the above.
Anyhow, this listing has a power switch and other users state it'll handle data.
https://www.amazon.co.uk/USB-OFF-SWITCH ... B00RC1NFEI
Admittedly, the switch is in a poor place. What you need is a cable with a switch in it, of which there are loads, but all the ones I've checked don't carry data.
You might get luckier through, I've not got the time to check all that many. One of the lads here runs a powered hub with switchs on it for the same reason.
Pete Kaine
Postby DanR » Fri Nov 29, 2019 12:16 pm
Pete Kaine wrote:Dammit... timed out before coming back to reedit the above.
Thanks, looks useful.
A powered hub I think would work.
DanR
Postby DanR » Fri Nov 29, 2019 12:28 pm
John Egan wrote:My Scarlett 18i6 (first generation) fires up perfectly when the system is switched on. I am using ASIO4ALL V2 drivers with the DAW and the latest drivers downloaded from the Focusrite site with other software. John
That’s interesting. So the Focusrite drivers don’t work so well in the DAW?
DanR
Postby John Egan » Fri Nov 29, 2019 8:08 pm
Not at all ! It's just that I like to switch between several interfaces quickly.
Regards, John
John Egan
Postby ef37a » Fri Nov 29, 2019 10:45 pm
Regards, John
Oh! In Samplitudes, any of 3 versions, I can just select the AI I want out of an NI KA6, my latest UMC204HD or indeed the PCI 2496 and all use their own ASIO drivers.
Years ago I had a Behringer BCA2000 and that would never start up but if I ran 'check for hardware changes' in Dev Mang is would fire up. REALLY crap drivers mind.
Postby John Egan » Sat Nov 30, 2019 1:04 am
ef37a wrote:That’s interesting. So the Focusrite drivers don’t work so well in the DAW?
Regards, John[/quote]
Dave.[/quote]
You're absolutely right, Dave and I can change drivers that way in Reason but it feels less clunky to me to use ASIO4All. I can leave the control panel permanently parked in the corner of the screen and leave almost everything else visible. Differenr folks, different strokes I guess.
Regards, John
John Egan
Postby DanR » Sat Nov 30, 2019 11:46 am
Just wondering if there’s any noticeable latency with ASIO4ALL when triggering the sounds in Reason.
My Scarlett 2i2 works well using a USB powered Roland A500 Pro to play the sounds in Cubase Elements.
Thinking of trying ASIO4ALL to see if it can power up the Focusrite interface.
DanR
Postby John Egan » Sat Nov 30, 2019 12:35 pm
DanR wrote:Just wondering if there’s any noticeable latency with ASIO4ALL when triggering the sounds in Reason.
Nothing noticeable, but my stuff is pretty simple, guitar based 50s and 60s style blues, rock and pop
John Egan
Postby ef37a » Sat Nov 30, 2019 12:51 pm
FWIIW. My son found playing a synth or drums in Cubase Ess6 with an Evo 49 controller and a 2496 card* gave him good enough latency. However, when he played along with previously recorded tracks the card was only just enough fast enough with its lowest, 64 samples setting. I would guess ASIO4all would not have cut it?
*Using the (indispensable IMHO DIN ports of course!)
Postby DanR » Sat Nov 30, 2019 1:40 pm
Thanks :thumbup:
DanR
Postby DanR » Sat Nov 30, 2019 1:55 pm
Yes. Can be a challenge getting everything working well together.
Makes me want to go back to my Yamaha AW1600 audio recorder!
DanR
Postby DanR » Mon Dec 02, 2019 1:26 pm
John Egan wrote:I am using ASIO4ALL V2 drivers with the DAW and the latest drivers downloaded from the Focusrite site with other software
I’ve installed the ASIO4ALL V2 drivers to use with Cubase and my old version of Reason and they work really well.
Using laptop onboard sound with headphones from the mini jack and no noticeable latency playing soft synths from the Roland (12.245ms, 320 samples buffer size).
I assume you monitor DAW audio via the PC onboard sound.
I only need the Scarlett 2i2 for occasional audio recording of hardware synths so can leave unplugged.
Still would like it to power up when starting Windows as the seperate headphone/main output controls are useful. I can leave it unplugged though and then plug and power on when needed.
Thanks for the ASIO4All idea.
DanR
