Komplete 6 unit USB socket dead - How to replace
Page 1 of 11
PostPosted: Tue Dec 10, 2019 2:00 pm
by Marbury
I have had the Native Instruments Komplete Audio 6 unit for a few years but from day 1 the usb has always been dodgy. Very wobbly and intermittent crackling every so often which got worse as the years progressed. Its never been manhandled or taken out the studio so the build is very poor considering. Now it has Kompletely died and no power. Swapped cables, re-booted pc etc and nothing. Wiggled the usb in the socket which crashed the pc and caused the psu plugs fuse to die. Not good,.
Basically, can anyone advise where to get a replacement usb socket and if easy to fit as I am a novice with the soldering iron ?
Re: Komplete 6 unit USB socket dead - How to replace
PostPosted: Tue Dec 10, 2019 3:31 pm
by James Perrett
It is more likely that the existing socket was never soldered properly so I'd suggest heating up the connection to each pin on the connector and allowing the solder to flow. You'll need a soldering iron designed for lead free solder to work on something this recent.
PostPosted: Tue Dec 10, 2019 5:16 pm
by ef37a
James Perrett wrote:It is more likely that the existing socket was never soldered properly so I'd suggest heating up the connection to each pin on the connector and allowing the solder to flow. You'll need a soldering iron designed for lead free solder to work on something this recent.
I wouldn't James. WTGR if the OP has beginner soldering skills, the USB PCB of a £160 interface is not the place to start!
Best bet is to first ask the reatiler it came from. Maybe (ho! ho! ho! They have a service dept, The 'hos' were not Christmas related)
If, as I suspect, they wash their hands try Native Instruments, could be a UK service agent? Last hope is a local man. Anyone who purports to be able to fix TVs and phones should be capable, even if he has never seen an AI before. Wish I was still in the business, love to help.
As for the KA6 being of "poor build quality"? No sir! Mine is the proverbial BSH and the 'B' port a much tighter 'grab' than any other AI I have known including an 8I6. You got a bad one (why did you accept it?) 't'appen.
PostPosted: Tue Dec 10, 2019 7:19 pm
by Marbury
Thanks James, I was wondering why my old soldering iron wasn't working on removing another usb component for transplanting. Having said that, I will try what you say and re-solder to see if it works thanks.
PostPosted: Tue Dec 10, 2019 7:24 pm
by Marbury
Well I purchased it from Dawsons a few years ago from a branch now gone. Its well out of warranty and NI are about as much use as Alesis with their customer service. To be fair this problem has got worse over time and its VERY common with many people. Just Google it.
As for taking it apart, I watched a Youtube video and its built like Fort Knox. Unbelievably difficult to take apart and then reassemble.
PostPosted: Tue Dec 10, 2019 8:27 pm
by ef37a
Hmm, very surprised to hear about a problem with the USB port. As I say, mine is a solid as a rock and I know of at least two other users on forums. I have also been touting the fine qualities of the KA6 on forums for many years, not had one single "Ah but! The usb ports are dodgy"
In fact negative reports of any kind are extremely rare, way fewer than say Focusrites though I will admit they probably outsell all other AIs combined in the sub $200 market.
Good luck any way with the slobbering. It is usually best to remove as much old solder as you can with wick (do not like crash-bang suckers) then flow in new. Then put a glass on it and check for shorts or whiskers before power up.
PostPosted: Wed Dec 11, 2019 10:18 am
by Marbury
Thanks for your suggestions. I have had no end of problems with the K6 over the years, randomly throwing out my audio settings in my DAW, failing to engage when booting up PC if not left a few seconds before powering up (resulting in green light flashing causing me to have to unplug the USB and in again to get it to see the K6 and intermittent crackling and popping (again having to unplug and re-insert the usb.
Having said that, as a novice, I don't quite follow some of your instructions: "Crash bang suckers" "put a glass on it" and "check for shorts and whiskers" ?
My old soldering iron and wick will not remove a donor usb from another scrap circuit board despite the iron being up to temp. For the life of me it does not melt the solder. If you could advise on the type of iron (and solder) I need I would be grateful. Also flux ?
As it was a tax deductible business item when I purchased it, I could have it mended and again, as a business expense but I can't really be without it for long as I need to be able to produce work. I could opt for buying a newer model (or other brand) but I hate to waste gear if only the usb being the issue. I am genuinely in a conundrum about it as its not been a great year for me (personally speaking) and this is almost a straw that could break the camel's back if I let it get to me. The thought of getting the unit open fills me with dread if you watch this video
https://www.youtube.com/watch?v=PglvI2CbGvQ&t=1711s
PostPosted: Wed Dec 11, 2019 10:52 am
by Wonks
They use a slightly different language on Dave's planet.
Crash-bang sucker - a solder sucker.
Glass - magnifying glass
Shorts and whiskers - any obvious solder short circuits between pins or PCB tracks that shouldn't be there and any stray strands of wire or solder that are bridging tracks on the PCB.
PostPosted: Wed Dec 11, 2019 11:02 am
by Marbury
Wonks wrote:They use a slightly different language on Dave's planet.
Ok, cheers. Might have to invest in a decent soldering kit from Amazon. Not too bad as they are not that expensive.
PostPosted: Wed Dec 11, 2019 12:35 pm
by Wonks
No, they aren't. Just be aware that the soldering iron kits that you get from Amazon in the £15-£20 range have terrible stands that need to be screwed down to a larger piece of wood to be stable, as they simply aren't big or heavy enough to be stable on their own. I bought one just for use on lead-free connections, and its temperature control facility isn't bad at all. But don't leave it at the default full-on temp, that will be too hot and is likely to damage the PCB tracks.
The solder used on the NI unit will be lead-free, which melts at a higher temperature than older 60/40 lead solder. The solders aren't compatible, so you'll need some lead-free solder to solder on a new socket.
Lead-free melts at around 217°C (leaded is around 183°C), and you need the iron to be a bit hotter than that to melt the solder fairly quickly, so somewhere in the 240°C-250°C region.
PostPosted: Wed Dec 11, 2019 12:59 pm
by Pete Kaine
Marbury wrote:Ok, cheers. Might have to invest in a decent soldering kit from Amazon. Not too bad as they are not that expensive.
I used to think this until the point where my friendly local neighbourhood soldering geek showed me the price of what he considered to be a decent soldering kit... :lol:
Still, the Cheaper Amazon ones should still get the job done.
PostPosted: Wed Dec 11, 2019 2:55 pm
by ef37a
'Hakko' mahap Pete? Used one, superb. There is a solder station at CPC Farnell 'DuraTool' I think. Had the Maplin version fo years, pretty good for around £45.
Sorry about the terminolgy botheration! I would suggest ALL you issues with the KA6 stem from a dodgy USB port or there is an issue with the PC?
Hate to say it but if you just need a 2 in 2 out AI pro tem, get a Behringer UMC thang. No 'pro' should be without a backup.
PostPosted: Wed Dec 11, 2019 3:32 pm
by Marbury
I think you should remember Pete when you had my PC built, the trouble you had with the K6 not handshaking when booting up. You fixed the issue only for me to say when I had got it home that it was doing it again. The only way of getting it to engage at boot up is to wait about 10 seconds before pressing the power button. Any less or longer and it flashes as not engaged. Its always been trouble.
Anyway, this seems a good kit
https://www.amazon.co.uk/dp/B07F2XNTWV/ ... ljaz10cnVl
PostPosted: Wed Dec 11, 2019 4:23 pm
by Folderol
There simply must have been something wrong with the KA6 internally from the start. My one has not given the slightest sign of problems, and I've had it for years, and taken it half way round Europe for various events, as well as using it at home, and all day sessions at the last 3 SynthFest events.
PostPosted: Wed Dec 11, 2019 5:34 pm
by ef37a
Folderol wrote:There simply must have been something wrong with the KA6 internally from the start. My one has not given the slightest sign of problems, and I've had it for years, and taken it half way round Europe for various events, as well as using it at home, and all day sessions at the last 3 SynthFest events.
Mine has not travelled (except to Will and back) but it has been used on many PC platforms: XP, 2000, W7 even Blista and always booted straight up no bother . I know of at least two working on macs and Will runs one in Linux. In the time I have had it mine has been installed on at least 5 laptops and towers.
I refuse to believe such a versatile and solid device has the operational bad history you suggest.
