Can I use a SW Preamp for Dynamic Mic for ESI Juli@ Soundcard
Postby Baldo » Tue Mar 31, 2020 3:00 pm
I want to use a Sennheiser Dynamic Mic as the input for for ESI Juli@ soundcard but the SC only has non balanced inputs (RCA or 6.3mm Jack).
I have a decent analogue mixer with Pre amps in it (Allen & Heath MixWizard). Could I connect the mic to the mixer and then take a direct aux out from the mixer and feed that into the RCA input into the SC?
Alternatively, can I by pass the mixer and use a SW preamp plugin to boost the dynamic mic signal within the PC?
Many thanks
Baldo.
Baldo
"Never put a recording studio in your home, it is a black hole into which you can pour unlimited amounts of money" Pete Waterman.
Re: Can I use a SW Preamp for Dynamic Mic for ESI Juli@ Soundcard
Postby James Perrett » Tue Mar 31, 2020 3:06 pm
You need a hardware preamp to connect a mic to your soundcard. If you try to do this just by boosting the level in software you'll end up with a very noisy signal - and possibly a slightly different sound as the input on the soundcard will have a higher impedance than the mic is expecting.
So using the mixer as a preamp is going to be the best way to do this.
Postby resistorman » Tue Mar 31, 2020 3:34 pm
Since the Mix Wizard has direct outs for each channel, you could patch right into the interface without running through the rest of the mixer.
resistorman
Postby Baldo » Tue Mar 31, 2020 3:51 pm
Thanks guys.
So the SW option is a no brainer. lets forget that then.
In terms of the HW option, my mixer does have a "Dir Out" for each channel. I assume that this can be used and patched into my SC input. I also assume that the EQ on that channel is available so my EQd signal is fed into the SC rather than just the raw unprocessed signal.
Baldo
Postby resistorman » Tue Mar 31, 2020 6:20 pm
Here’s the block diagram:
https://www.allen-heath.com/media/WZ4+1 ... iagram.pdf
Looks like it’s post eq pre fader with the jumpers at default.
resistorman
Postby Baldo » Tue Mar 31, 2020 7:57 pm
Perfect. Thanks Guys. This works.
into the mixer and out again into the SC. Nice clean signal from the mic.
Baldo
