Intel dp35dp - Can I install windows 10?
Postby Johnny Stecchino » Thu Apr 16, 2020 5:21 pm
In the last 3 years I didn’t use my desktop and now decided to reuse it if possible.
I have the old DP35DP MOBO of Intel and tried to install windows 10 64bit on it (still got XP 32bit) to no avail. In their site intel gives the Windows 7 as last option and I didn’t find any proper answer on the net for this question.
Does anyone here had a successful installation on this MOBO?
Thanks in advance!
Johnny Stecchino
Pro. violinist who likes some experiments...
Re: Intel dp35dp - Can I install windows 10?
Postby resistorman » Fri Apr 17, 2020 12:20 am
Have you tried installing Win 10 32 bit?
resistorman
Postby Johnny Stecchino » Fri Apr 17, 2020 9:34 am
Hi resistorman,
Point was to move to a 64bit system so I can use 8GB ram, otherwise will stay with XP.
If can’t do it the 10 way will opt for windows 7.
Johnny Stecchino
Postby Pete Kaine » Fri Apr 17, 2020 9:58 am
The chances are you may have to try this yourself, so if you have a spare drive you can download the Windows image from the MS site to try it in trial mode, with whatever last set of drivers you can find given that most w7 drivers work on w10 for a lot of kit.
Given that generation of the board, I would have said no, as support would have been dropped long before W10. But being an Intel model the parts were always well supported and drivers often worked across OS generations, so I wouldn't be surprised if some support existed for the majority if not all of it, but it might take some digging around.
Well, with that said with it being Intel I also wouldn't be that surprised if enough were in the base W10 image to get it working either. intel stopped selling consumer boards during the W7 generation, so I wouldn't be shocked at the download page being poorly maintained even if they did exist.
Pete Kaine
Postby Johnny Stecchino » Fri Apr 17, 2020 4:27 pm
Thnx Pete,
actually before writing here I did burn a W10 image to a DVD but my system didn’t even boot from the dvd, just didn’t recognized it. I double checked with a laptop which has W7 as OS and it did recognize the DVD so this is where my doubts started and I posted here.
Johnny Stecchino
Postby Pete Kaine » Mon Apr 20, 2020 9:28 am
Assuming you've got the optical set up in the boot order correctly on that Intel board, the DVD should at least run and get past the first part with keyboard & language selection.
Try burning on another brand of media if you can, or/and try another optical drive if possible.
Pete Kaine
Postby Johnny Stecchino » Mon Apr 20, 2020 9:32 pm
Pete Kaine wrote:Assuming you've got the optical set up in the boot order correctly on that Intel board, the DVD should at least run and get past the first part with keyboard & language selection.
Will do shortly and will report.
Cheers!
Johnny Stecchino
Postby Johnny Stecchino » Tue Apr 21, 2020 10:37 pm
I tried again today but
“SORRY, COMPUTER SAY NOOOOOOO :headbang: “
There is a dos sort of page which says
1.
2.
Select CD-Rom Boot Type:_
I check out and saw that this is a problem people with mac face. Wonder what’s going on. Anyway maybe I should go for W7 64bit. :shocked:
Johnny Stecchino
Postby Pete Kaine » Wed Apr 22, 2020 9:33 am
Yeah, I can see a load of MAC forum questions about this too, mostly to do with dual booting none MAC OS builds. MAC's were using Intel hardware at that point though, so I wouldn't rule this out as a possible fix.
I followed a few threads through people doing W8.1 installs were stating that this following method works.
https://medium.com/@mark.stanislav/fixi ... .dl3olstb9
The guy is running Linux but suggests it should work for any OS, for want of a better suggestion It might be worth a last-ditch attempt before falling back to W7.
Pete Kaine
Postby Johnny Stecchino » Wed Apr 22, 2020 11:37 pm
Pete, you are my man!
I had actually another problem to resolve later, since windows didn’t recognize my SSD but found this link which helped to resolve the problem:
https://www.youtube.com/watch?v=tgQ-KP0Zh8U
So now I can confirm:
It is possible to instal and run W10 64 bit on the Intel DP35DP (what an upgrade - had XP 32 before...).
Thanks again!
Jonathan
Johnny Stecchino
Postby Pete Kaine » Thu Apr 23, 2020 11:46 am
Great news! Thanks for the feedback, it might well come in handy again.
Pete Kaine
Postby Guest » Wed Jul 01, 2020 7:57 am
The best medium for installing Windows 10 is the installation disk.
Guest
Postby The Korff » Wed Jul 01, 2020 1:48 pm
Great board, the DP35DP (I still get slightly nostalgic about it, specifically about how it solved all my PCI Overflow error messages when I was using Creamware DSP cards).
The Korff
Postby djhurt1 » Fri Mar 05, 2021 12:01 am
I realize this thread is almost a year old now. I registered here because I found this searching for this specific board. I admit I have no other knowledge of the discussions in this forum but please bare with me. I upgraded my PC with this very board to Win10 recently but for the life of me I cannot find a Win10 compatible driver for the Intel Management Engine. OP, did you have any issue with the driver for the IME or even better, do you have a copy of the driver? I'd love to get a couple more years out of this PC before updating if possible.
djhurt1
Postby djhurt1 » Sun Mar 07, 2021 3:30 am
Luckily I finally found a compatible driver for Windows 10 it seems. If anyones interested, let me know and I can email it to you or whatever works for you.
djhurt1
